New Guy fomr the north!
Old Jun 8, 2009 | 07:09 PM
YeTI_north's Avatar
I am more looking for information on my engine then a full car. I have a 53 Buick Special that I am putting in a 70' 455 into I seen some guys do the swap and I was looking for info on that and on the 455 tweaks to make it last. As I said I am form Northern Ontario and the older cars (any thing past the 80"s) are tuff to find and in any shape to work with. I ended up with 2 53's by fluke and the 455 was a gift from a good friend.
YeTI
Old Jun 8, 2009 | 07:46 PM
gearheads78's Avatar
car guy
welcome.......53 Buicks are sweet cars
Old Jun 8, 2009 | 08:15 PM
2blu442's Avatar
Just to clarify, this is a 1970 Olds 455 that your using? They are different from the Buick 455's. At least a couple guys on this board have put a 455 into an earlier Olds, they may be able to give you some pointers with the installation. You might surf the big block forum to see what others have done to their 455's. John
Old Jun 9, 2009 | 03:11 AM
YeTI_north's Avatar
Yes it is an Olds 455
Yes it is a Olds 455 not a Buick 455. I am info junky so I pal to do a lot of reading
YeTI
Old Jun 9, 2009 | 04:17 AM
derek nesdoly's Avatar
olds..older..oldest
Welcome to the site and good luck with your project. My dad was a Buick man....I broke that tradition with my 442. Good to have another Canuck on board,even if it's a black fly bitten Yeti!! How far north are you? How good is the fishing? If you can't get your questions answered on this site,they can't be answered at all !Derek
Old Jun 9, 2009 | 04:25 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. The biggest changes I had to make to install the 455 into my '46 Oldsmobile were:
Fabricate something to mount the engine on since the original engine used a the front cross-member as a mount. Had to make to boxes that extended inward toward the engine from the frame rails.
Fabricate a transmission mount for the TH400 transmission.
Modify the drive shaft to fit between the transmission and the rear axle.
Purchase an aftermarket radiator and modify the radiator lower and side rails to fit it, and modify the upper and lower hoses to fit the engine from the radiator.
Remove the original battery box and mount the battery in the big space between the right front fender and the bumper, behind the radiator grille.
Purchase an aftermarket floor shifter that mounted directly onto the transmission and cut the floor board to accommodate it.
Purchase an aftermarket transmission cooler and build/route hard lines from the transmission to a spot in front of the radiator.
Modify existing exhaust manifolds so the downtubes would fit in the '46 frame.
Various odds and ends, hardware, plumbing, etc.
Old Jun 9, 2009 | 06:49 AM
citcapp's Avatar
https://classicoldsmobile.com/forums...gine-swap.html
Try this link. I installed a 455 and turbo 400 into my 57 Olds and detailed the install with pictures and drawings including the engine build up as well
Old Jun 9, 2009 | 08:06 PM
88 coupe's Avatar
Junior Member
Originally Posted by YeTI_north
........ I have a 53 buick ........
B or C body?
Norm
Old Jun 10, 2009 | 03:23 AM
YeTI_north's Avatar
Ya that would be some good added info I do not know if it is B or C it is a 53 Buick Special I know it is a 40 series. I am new the Buicks I am more of a Caprice/Impala guy (witch I know are b-body’s)
YeTI
Old Jun 10, 2009 | 02:37 PM
88 coupe's Avatar
Junior Member
........ it is a 53 Buick Special ........
That would make it a B body, same as Olds 88 and Super 88.
Norm
Old Jun 10, 2009 | 03:23 PM
ozoneblue's Avatar
Wink Welcome
Welcome Joe might be able to fill in the blanks But like Dan said {piece of cake????}
Old Jun 12, 2009 | 05:04 PM
YeTI_north's Avatar
It looks like he swapped a v8 for a v8 I am doing a strait 8 for v8 I look foreword to the challenge
YETI
Old Jun 13, 2009 | 08:25 AM
citcapp's Avatar
Keep us posted on your progress and post some pictures of the swap. It helps inspire the rest of us to keep moving foward on our in progress builds
Old Jun 13, 2009 | 10:53 AM
YeTI_north's Avatar
I will I have some pix of the Scrap strip down I will post.
YeTI
bgoble
Jun 19, 2015 04:54 PM
CarCrazyChemist
Apr 1, 2014 08:16 AM
nine8
Jul 31, 2013 08:02 PM
Shawn M
Mar 23, 2013 02:01 PM
chillyw31
Nov 20, 2009 01:52 PM
