New found olds love
New found olds love
Hi all!
I bought a 1971 cutlass S coupe last year and now I'm starting to dig into the project.
It currently has:
1969 seasoned 455 big block bored 0.030 over
10 to 1 compression
mildly ported c cast iron heads
headers
850 mighty demon double pumper
griffin 4 core radiator
turbo 400 with shift kit
custom drive shaft
8.5" corporate axle with 3.73 richmond gears with auburn pro gear
edelbrock 4 link suspension
My end goal is to create a fast and reliable sports car. That can handle as well as burn rubber in a straight line. I love this body style so I'd rather invest the money into an older car rather then buy a new corvette.
Upgrade in progress:
B and M stealth ratchet shifter
Possible upgrades:
6 speed tremec vs gear vendor overdrive?
ported aluminum heads with big valves
488 or 496 stoke?
Pro touring frame and suspension?
Any advice is always welcome!
It currently has:
10 to 1 compression
headers
custom drive shaft
Possible upgrades:
488 or 496 stoke?
It is nice! But I feel like the engine could run just a bit better plus I need to get rid of the stock connecting rods! And the body needs some work... too many extra air vents aha. I drive the car a lot and put a decent amount of time on the highway so not having the overdrive is getting slightly annoying!
Welcome to the forum, thanks a lot for joining. You did a great job and I'm sure the result will be impressive. This forum is incredibly informative and its plenty of inspiring ideas for your project!
