new and forgetfull
Old May 15, 2011 | 05:05 PM
golds56's Avatar
new and forgetfull
Hi I am Glen from michigan,I took my 56 apart about 6-7 years ago and forgot a few things,like what goes on the two holes rearward of the heads ? I know they are coolant related but i cannot find anything in the original shop manual.Any one have a picture? I just got it back from the engine shop and had a complete rebuild done with a bit of extras like balanceing and cam grind,diamond forged 80 over pistons.Had the block powdercoated irridescent blue and chrome coated the tripower intake. Thanks in advance golds56.oh i have a 56 olds two door post with a 324 v8 and jetaway trans,the body is in primer and getting ready for twotone .
Old May 16, 2011 | 06:30 AM
Oldsguy's Avatar
Past Administrator
Sounds like an exciting project. Welcome to our site, hope someone can come up with some good info for you about those two holes.
Old May 17, 2011 | 05:20 AM
Welcome
Welcome aboard
I'm glad I'm not the only one who forget's things.
Old May 17, 2011 | 05:34 AM
cutlassgal's Avatar
Cutlass Lover
Welcome to our site!
Old May 17, 2011 | 06:50 AM
Olds Dad's Avatar
Collector of Stray 55's
Hi - I have a lot of disassembly photos of my '55 324 - if you send along a couple of pics of the areas you're questioning I can try to find a corresponding photo to see what goes there - no promises but I'll see what I can dig up!
Gordon
Old May 17, 2011 | 08:15 AM
Julian P's Avatar
On my 57 371 on the passenger side rear of the head is the water outlet for the heater, on the drivers side is where the water temp switch goes. i would think that yours would be the same...
Old May 17, 2011 | 08:22 AM
Olds Dad's Avatar
Photo is a '55 324.
Hope it helps
Gordon
Old May 17, 2011 | 11:02 AM
golds56's Avatar
Thats a good pic gordon thanks.If you could blow up my sig picture you woud be able to see the two suspect holes i asked about.Not sure how to post any other pics just yet.And thank you all for the howdy dos.So where does that hose go from there gordon?I wonder what box my temp sender is in,or if i can buy a new one somewhere? mabey this will work for a picture.Glen
Old May 17, 2011 | 11:10 AM
Olds Dad's Avatar
See house routing in photo (red lines) - goes to heater control valve
Pretty sure you can buy the temp sending unit, but the plate it mounts to likely no - I'm sure you could come up with one if you needed it - anyone with a spare engine would have it
Old May 17, 2011 | 11:13 AM
golds56's Avatar
Wow dude your fast ,thanks again .I did get the photo to load in the last post if you want to see it.Glen
Old May 17, 2011 | 12:06 PM
Olds Dad's Avatar
Nice - what's the 3-2 setup from?
Old May 18, 2011 | 03:46 AM
golds56's Avatar
a 57 olds 88 a guy that worked for me ,his brother actually inherited his familys home .He found it in the barn and remembered his dad putting it on the shelf 30 years or so ago ,he knew what it was because he is a tri-power nut and had five of them looking like new in his kitchen,yes he was single,and yes the were for 442s.Greg at gregs cylinder heads in riverview had to do a bit of work on them and add a depression in the valley pan .I sent them out through mayfair racing and had them chrome coated.
Old May 18, 2011 | 05:31 AM
Olds Dad's Avatar
that barn doesn't happen to be in Palmer, Ma. does it?
Old May 18, 2011 | 10:04 AM
golds56's Avatar
Nope its in Brownstown mi.,I found ,sandblasted and painted the two parts i was looking for the sender actually goes in part of a throttle linkage braket.I ordered a new temp sender from carquest for 15 bucks .Next question is why didnt the po tighten the flexplate bolts ? Anybody have one for sale?And where could a guy find a pair of performance headders for this thing? Glen
Old May 21, 2011 | 05:23 PM
hialeah56's Avatar
1956 holiday coupe
Welcome to CO, I just found this topic, come down to the vintage section we have a nice topic just for 56 owners and if you need any help I'll try my best
https://classicoldsmobile.com/forums...owners-ck.html
Erit
Old Oct 5, 2011 | 03:24 AM
golds56's Avatar
lots done now
I have her in primer and the doors and trunk and body edged,new floor pans are in and engine is almost complete (need to get linkage togeather for tri-p).I could use some info and a few pics of the front radiator braces and splashpans,hood interior with braces and the insides of the doors where the weatherstrips and seals go.My other laptop crashed and burned so i lost most all my pics .Thanks in advance as she wants this thing out of the garage and i think i can bargain in a new pole barn if its done.
Old Oct 10, 2011 | 12:47 AM
spiderjason's Avatar
Welcome!!!! Glad your here!!!
Sickle
Aug 31, 2013 08:28 AM
ah64pilot
Sep 19, 2012 10:55 AM
ah64pilot
Aug 17, 2012 02:36 PM
Steeb
Feb 18, 2009 02:01 PM
henryk8398
Ninety-Eight
Jan 24, 2009 07:49 AM
