Need help tracking coolent leak?
So I found out I had a exhaust manifold leak on my 394. I replaced the gaskets and it sounds way better now but now looks like I have a coolent leak under the intake manifold, I can see a puddle under there and leaks tru the back. Anybody know what this might be?
You can go to O'Reilly and borrow a leak tester. It has a pump to put on your radiator in place of the cap. Pump it up and pressurize the system and you may see where the water is coming from. I did this on a 94 Corvette I had and it worked great.
There is an inlet on the rear of the right cylinder head and runs to the heater control valve. It connects to the head with two bolts which means it has a gasket under it. A leak there would probably leak down onto the valley cover.
