Need advice,
Old Jul 7, 2016 | 06:49 PM
OldsCaddy's Avatar
Need advice,
Hi everyone, I have a 74 350 with low miles that I disassembled and attempting to rebuild. I know some times its better to just take it to a machine shop. If I have to bore it than so be it, I plan to measure clearances tomorrow. If all checks out will these black marks be a problem?
Old Jul 7, 2016 | 06:57 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If you are not boring it, you should hone the cylinders. A good hone will probably clean those up. What caused them?
Old Jul 8, 2016 | 12:25 PM
OldsCaddy's Avatar
Believe it or not this is after flex honing. From what I've read its rust that occurs in a low oxygen environment. Has anyone ran in to this?
Old Jul 8, 2016 | 01:24 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
This is my opinion having rebuilt many engines...You will never have proper oil control, you will lose compression and have excessive blow by... period. You will need an over bore to do it correctly.
The hone marks are not right either. They are too horizontal.
A good house has a good foundation...same goes for an engine.
ah7910
Oct 21, 2014 06:58 PM
1987supreme305
Apr 30, 2007 04:21 PM
TennesseeDelta
Mar 27, 2007 08:18 AM
Sun City 70
Mar 3, 2007 10:16 PM
rtdoff04
Jan 16, 2007 06:39 PM
