My new baby
Old Oct 12, 2023 | 03:23 PM
7thof11's Avatar
My new baby
All my horn and electrical problems are fixed. Much help from you all and the mechanic from MGM. I've been so worried about those problems that I knew that it's been running rich. I have only been putting in high test gas because I've heard that older engines don't like the regular stuff. I've never owed a 4 bbl carb. Is there a simple fix?
Old Oct 12, 2023 | 04:56 PM
This car will run fine on regular gas. It is a low compression engine, 8.5:1. Use Sta-Bil ethanol treatment with your fill ups to counter the ethanol in todays gas, or it will wreak havoc on your fuel system.
Old Oct 12, 2023 | 05:19 PM
If your engine is running rich then this is what you need to do a tune up. Use a timing light, vacuum gauge, dwell/tachometer and a set of feeler gauges. @$$uming your Olds has the OE points distributor.
1) Take your distributor cap off and set your point gap with the feeler gauges.
2) Reinstall the cap and start the car to set the dwell.
3) Use the timing light to set your timing.
4) Adjust your fast idle with the dwell/tachometer.
5) Use your vacuum gauges and set your idle mixture screws to maximum vacuum.
6) Reset your fast idle since it might be a bit off after adjusting your idle mixture screws.
Old Oct 12, 2023 | 05:34 PM
Don't forget when you are setting your timing you must disconnect the vacuum advance canister vacuum hose from the distributor and plug that vacuum hose. After setting your timing, re-connect the vacuum advance canister vacuum hose prior to adjusting your A/F mixture screws.
Old Oct 12, 2023 | 06:34 PM
Charlie Jones's Avatar
Phantom Phixer
Here's a simpler way. From a guy with over 50 years doing tuneups on these cars.
1. Leave your feeler guages in your toolbox.
2. Start the car and adjust the dwell to 30 degrees. If you just installed new points, they will be factory adjusted close enough for the engine to run. If not, dwell can be adjusted while cranking.
3. Follow instructions 3 thru 6 above.
Old Oct 25, 2023 | 06:44 PM
Blafau's Avatar
Beautiful. A real head-turner
Phoenix8990
Jun 26, 2021 06:41 PM
joe_padavano
Jun 22, 2017 07:21 AM
Hydro462
Jan 16, 2010 08:38 PM
sbshafer2
Oct 30, 2009 08:54 AM
