motor swap
Old Mar 15, 2011 | 12:43 PM
DNICE's Avatar
motor swap
thinking about putting 455 in a 1985 monte carlo or a 78 olds cutlass.will it fit?
Old Mar 15, 2011 | 01:31 PM
gearheads78's Avatar
car guy
Like a glove. Just find some 307 G-body mounts
Old Mar 16, 2011 | 01:46 AM
DNICE's Avatar
thanks for the help.one more question guy is selling a 77 monte would that 455 fit in there to?
Old Mar 16, 2011 | 06:00 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, a BBO would fit nicely in that Cutlass, can't say about the Monte though. Someone will verify.
Old Mar 16, 2011 | 06:19 AM
All the 1978-88 A/G body cars are the same under the hood. As noted above, bolt the 307 Olds frame mounts to the crossmember and any Olds motor drops in using the Anchor P/N 2328 motor mounts.
Old Mar 17, 2011 | 08:36 PM
DNICE's Avatar
thanks guys for all the help.still looking for a cutlass or a buick regal.
Old Mar 17, 2011 | 10:59 PM
svnt442's Avatar
If you get a 78 that came with a 260 you're G2G on the frame mounts as well. I had a 260, 350 and a 455 all on the same frame mounts in the 80 I used to own.
Old Mar 18, 2011 | 08:30 PM
DNICE's Avatar
thanks for the help.but i need to know will a 455 fit in a 1982 monte carlo.
Old Mar 19, 2011 | 12:39 AM
svnt442's Avatar
Same frame from 78-88. All you need is the correct frame mounts and wiring and you're G2G.
Old Mar 19, 2011 | 07:06 AM
You might want to scroll up and re-read the answers to your first question:
Old Mar 19, 2011 | 10:24 AM
442_Mustang's Avatar
I'm thinking about putting 455 in a 79 olds cutlass.will it fit?
Old Mar 19, 2011 | 12:51 PM
svnt442's Avatar
Joe has this become a broken record or something? I could have sworn that question has been answered in this thread at least 3 times already now.
Old Mar 19, 2011 | 01:14 PM
arodenhiser's Avatar
STOP call'n it a Chevelle
Do you think I could fit a bbo 455 in a 1983 el Camino?
I should be careful, I don't want to p-off the Chebby guys.
Adam
P.S. Sorry for bening a smart ***!
Old Mar 19, 2011 | 03:54 PM
Uh... I know. A bit of sarcasm here??? I always try to do a search before I ask questions cuz they have usually been covered. Bet I know where someone would love to see if a 455 will fit...
Old Mar 19, 2011 | 05:34 PM
DNICE's Avatar
sorry for asking the same question twice iam new to swaping motors in different models.i have steel motor mounts in there now can i use them?and where do i get p/n2328 motor mounts from.
Old Mar 19, 2011 | 06:41 PM
So, I've got this old olds.
Think there's enough room there to drop in a BBO?
And will it fit with no mods?
ps: check out my kewl 28" dubs:
Old Mar 19, 2011 | 06:54 PM
In the USA I would loook at Advance Autoparts, NAPA, Autozone or and large chain will either have them or order them in. In Canada any UAP/Napa or Canadian Tire will have or order them for you.
http://shop.advanceautoparts.com/web...R%7CGRPENGPAMS____
Adam
Old Mar 19, 2011 | 07:18 PM
DNICE's Avatar
I have shorty headers in the olds 98 now can i use them in the monte carlo.
Old Mar 20, 2011 | 07:27 AM
The 1978-88 A/G body cars are mechanically identical, despite differences in external sheet metal. The frames are pre-drilled to accept the motor mounts for pretty much any engine GM made at the time.
Unbolt the old mounts. Bolt in the new ones. The new ones will not mount in the same location as the old ones.
Any auto parts store or on-line vendor like RockAuto.
Old Mar 20, 2011 | 06:58 PM
DNICE's Avatar
thanks for the help.but i meant iused steel mounts on the engine could i reuse them.
Old Mar 21, 2011 | 06:40 AM
What steel mounts? The only metal side engine mounts for an Olds motor are those used on the first gen Seville, the 1977-79 Trans Am and Firebird with Olds motors, the 1980-90 Fleetwood with 307, and the Chevy full size trucks with Olds diesel motors. These brackets mate to the Chevy clamshell frame mounts (though the truck brackets are different from the car brackets). If you have the car brackets, you should be able to bolt up to the clamshell mounts. If not, get the 307 frame brackets and use the Anchor rubber motor mounts.
Old Mar 21, 2011 | 07:38 AM
DNICE's Avatar
i brought them from mondelos.
Old Mar 21, 2011 | 07:55 AM
Twenty questions again...
Look, the mindreading thing STILL isn't working, so if you want a useful answer you have to provide COMPLETE information. Do you have AFTERMARKET metal brackets that replace the rubber motor mounts? If so, are these dimensional replacements for the Anchor 2328 mounts or for the Anchor 2261 mounts? The dimensions are different and the two do not interchange. If these brackets are dimensionally identical to the 2328 mounts then the will bolt to the 307 frame brackets. If they are dimensionally identical to 2261 mounts you can't use them.
In any case, you neither need nor want metal-to-metal motor mounts for a street driven car. If this is a track car that will see occasional street use, that's one thing, but a street car really doesn't want all metal mounts.
Old Mar 21, 2011 | 08:01 AM
DNICE's Avatar
well here's a little more info i have a 1982 olds 98 it had a 307 i yanked it out after i blew it up.found a 1970-1971 455 on ebay in a chevy malbiu.then i put it in the olds 98.know as you know i want to put it in the monte carlo.
Old Mar 21, 2011 | 08:45 AM
1ATony's Avatar
welcome to the site
'69CutlassVert'
Aug 25, 2011 07:19 AM
prrc
Jun 13, 2009 08:49 AM
michaeladamczak
Dec 27, 2006 08:00 AM
olds88
Jan 4, 2004 07:56 PM
