Looking for the stamp on the axle housing
Old Mar 27, 2018 | 08:51 PM
dstaff's Avatar
Hey guys...Newbie here. I just picked up a 71 442 numbers matching car (at least the vin, engine, and tranny so far). I have a 402227 rear but from what I read 70 was the last year for that rear. The car has power windows and ac with a column shift. Kind of a weird set up but also nice. I am wondering if Lansing just used up what they had and installed a 12 bolt type o anyway. Also where is the axle stamp commonly located. I have scuffed the tube to the right of the diff cover and the opposite side with no luck. Maybe I need to scuff some more.
Old Mar 28, 2018 | 05:26 AM
scottv442's Avatar
Maintained
keep trying...sometimes the stamp is lightly done. about 1/4" tall capitol letters.
sounds like a good car, show us some pics when you have time.
Old Mar 28, 2018 | 08:25 AM
lemoldsnut's Avatar
It is often on the passenger side axle tube on the back side about mid way between the spring perch and the center section. It is faint often and upside down.
Keep cleaning and trying it is very faint often.
Old Mar 28, 2018 | 11:37 AM
Here's a picture of one of my O-Type rears showing the location of the stamped code. It can be VERY hard to see due to rust, dirt, oil buildup, etc.
The blob of silicone RTV at the left side is where the axle vent hole is.
https://classicoldsmobile.com/forums...tial-code.html
As stated above, the numbers you referenced are basic housing casting numbers and you will need to look for the two letter code that is stamped on the passengers side axle tube. Below is a picture of the code on my 1968 O-Type (3.42:1 open).
michaeljay0862
Wheels and Tires
Aug 21, 2014 08:09 PM
jet tech
Drivetrain/Differentials
15
Dec 3, 2012 06:54 AM
sbFALL63
Sep 29, 2011 02:05 PM
cutlasssupreme71
Feb 22, 2011 11:40 AM
sbFALL63
Jun 4, 2010 05:36 AM
