Looking for a replacement carb for 64 f-85
Old Nov 18, 2019 | 10:49 PM
Steelman's Avatar
Hello, I an brand new to the forum, I have a 1964 f 85 and I believe it is the 330 V8. Looking to replace the stock carb with an aftermarket. Just looking for something that will fit the stock intake and hopefully fit the air cleaner.
am I lacking any information.
Also links to websites to purchase the carb would be great. Thanks
S
Old Nov 19, 2019 | 04:43 AM
Bfg's Avatar
Bfg
Why replace? Your better off rebuilding the original carb. This way you keep the original air breather.
Old Nov 19, 2019 | 04:50 AM
x2
Have you considered rebuilding the carburetor yourself? If you're handy with a wrench it isn't too difficult.
Old Nov 19, 2019 | 05:22 AM
I normally also suggest just rebuilding the original carb, but even I've had my butt kicked by the 4GC. I have no idea why - Qjets are easy for me.
In any case, be aware that the 4GC has a smaller diameter air horn than does any modern replacement carb. That means that nothing but another 4GC will work with the stock air cleaner.
Old Nov 19, 2019 | 10:53 AM
Steelman's Avatar
Carb rebuild
Thanks for the response. Rebuilding got me in to this mess. I had it rebuilt about a year ago when I went through the interior. It started leaking fuel shortly after that.
im willing to give it another shot. Do you happen know where or who I can send it to get rebuilt again?
it is really tempting to grab a new holly or q jet as they are cheaper than a rebuild.
Old Nov 19, 2019 | 12:27 PM
lunaboy's Avatar
The Rocket Astronomer
if you would like to give another core rebuild a try ; i have one correct for 64 330 auto with the tag.
here is the link:https://www.ebay.com/itm/333393493794
Old Nov 19, 2019 | 10:54 PM
Onit's Avatar
Mr Carburetor in Cedar Hill TX rebuilt my 4GC, 6 months ago. He did a great job 200$ kit included.
Keep your original base gasket if you have it. Re use it. Rebuild kits do not come with the original style more thick gasket. This will prevent heat soak on your carb.
Old Nov 20, 2019 | 04:54 AM
Steelman, did you attempt to rebuild the 4GC yourself? The price of a rebuild kit and a Saturday afternoon isn't too expensive.
Old Nov 20, 2019 | 06:37 AM
Steelman's Avatar
Thanks Olds 64. I did pay around $200 for the kit plus some labor. I think my next step is to pull it off and locate the he fuel leak. Hopefully it will be a loose screw or a bad gasket.
Old Nov 20, 2019 | 07:17 AM
4GC rebuild kits run about $30-$35 apiece.
https://quadrajetparts.com/carbureto...c-104_123.html
Old Nov 20, 2019 | 08:02 AM
Steelman's Avatar
I guess they saw me coming��.
what’s the old saying, “ trust but verify”
Old Nov 21, 2019 | 03:03 AM
yachtsmanbill's Avatar
Try Cliff. Well recommended and highly regarded! Pretty much only does GM carbs. Bill
https://cliffshighperformance.com/
1965F85_scholten
Oct 6, 2015 02:24 PM
jRoofgunner
Dec 23, 2013 09:25 PM
BStone
Aug 12, 2011 09:22 AM
yeahbuddy
Jun 1, 2010 05:38 AM
Keener
Apr 21, 2010 11:47 AM
