I'm a Newb, Im Purchasing a 442 Project!
Old Nov 14, 2012 | 10:34 AM
  #41
allyolds68's Avatar
Originally Posted by Allan R
So you're saying the key won't or shouldn't come out of the key cylinder unless the transmission is in reverse??
I'll save Joe the trouble of typing it again (from a quick search of "backdrive purpose")
A refresher for our younger members. Starting with the 1969 model year, the feds required that the shifter and steering column be locked with the key. GM's solution to this was to use the column shift style linkage on floor shift cars to ensure that the shifter was locked. On manual trans cars this linkage was connected to the reverse lever on the trans. Since this backdrive linkage needed to be in place anyway, GM saved production cost by using only one configuration of NSS/backup light switch - the one on the column. The backdrive linkage automatically moved the column-mounted switch for backup lights (even with a manual trans) and provided the NSS function for A/T floor shift cars. Manual trans cars used a separate clutch interlock switch that used the same wires as the NSS. The two purple wires were simply plugged into the clutch switch instead of the NSS on the column.
For the steering column to lock the key has to be removed (or at least the cylinder moved to the removal position), so I'd say yes
Old Nov 14, 2012 | 10:52 AM
  #42
Steven, you're getting me confused. Explain??
Old Nov 14, 2012 | 01:41 PM
  #43
stevengerard's Avatar
Once the car is started the driver should not be able to remove the key while the car is running. My ignition key cylinder was so worn that I could remove the key once the car was running. Seems trivial but was a nice feature. I could keep the car running on a cool night or while warming up and remove the keys, lock the doors and walk 20 feet away and not worry about the car being driven off since the doors were locked. Since I replaced the cylinder with a new one I can not remove the key unless the car is turned off.
On a side note, my ignition key starts my neighbors 70 convertible but his does not start mine.
Old Nov 14, 2012 | 01:55 PM
  #44
So do you need the car to be in reverse to take the key out? How does that backdrive linkage work to keep the key in?
Old Nov 14, 2012 | 09:06 PM
  #45
harlequin's Avatar
'70 442 Convertible
Got back late tonight from NH. I purchased the car! Got him to include delivery to CT too. When I first arrived the car was getting charged up and it was completely boxed in by a slew of killer muscle cars. The car started right up, pulled it outside and took it for a drive around. Honestly, the road to the shop was crazy so it was a good test drive to test the car. Handled nicely, I was sold. After thorough inspection, yes theres some rust but the car is sound and driveable in its current state. I plan on doing a frame off resto with this killer. Everything works except the reverse bumper lights, no biggy. Im having him do a few extra things, so the car isn't getting delivered until late dec early jan. I'll try to post a video and I'll post pics from my visit.
Old Nov 14, 2012 | 09:14 PM
  #46
harlequin's Avatar
'70 442 Convertible
Let me know if you guys can view the video. That's the owner and his mechanic in the car after they moved all the others. Not bad for 6 year old gas.
Old Nov 14, 2012 | 09:25 PM
  #47
Ok, after reading that carefully a couple times and looking at the MT linkages and AM pics of backdrive rod/connector, I get how it works now. Thanks Mike.
Old Nov 14, 2012 | 09:28 PM
  #48
harlequin's Avatar
'70 442 Convertible
soo, can you view the video alan?
Old Nov 14, 2012 | 09:32 PM
  #49
Yes. That does not sound like an Oldsmobile to me though. Maybe it's just the video? Why didn't he kick down the carb to a normal idle speed?
Old Nov 14, 2012 | 09:37 PM
  #50
harlequin's Avatar
'70 442 Convertible
lol, what do you expect from the looks of that engine! yea, the video is from my phone. Its weak, but kripe look at that engine never been pulled! Nothings been done to this car for 11yrs. Paint was done 12yrs ago, it was a crap paint job. I'll postr another of them adjusting carb.
Old Nov 14, 2012 | 09:47 PM
  #51
harlequin's Avatar
'70 442 Convertible
Here's the owner and his mechanic trying to tweak stuff and trying to sell me after mentioning that stuff
. They were fumbling around with the carb and the cover. Yes it does sound weak, but I'm very impressed that it did start and perform on the road. I mean $%^t, look at the the engine. I got some good pics of stuff that ill post soon.
Old Nov 14, 2012 | 10:29 PM
  #52
harlequin's Avatar
'70 442 Convertible
heres a couple of shots after they moved a few
Old Nov 14, 2012 | 10:30 PM
  #53
harlequin's Avatar
'70 442 Convertible
ill post some tomo, doesn't look like they went through
Old Nov 15, 2012 | 06:00 AM
  #54
61reoldsman's Avatar
Like a friend of mine says"pictures are deceiving" ,looks nice BUT be prepared to walk away if it doesn't live up to what you are expecting .$10K is not a drop in a bucket given the fact that body work and paint could be another $5-10K ,rebuilt motor possibly the same amount and all the little" odd and sods" parts are expensive .You could sink a lot of
money into the car and never get it back BUT if you plan on keeping it for a long time then
do whatever feels right .
Old Nov 15, 2012 | 06:04 AM
  #55
Yes. The linkage rotates a collar inside the steering column that prevents the key from rotating to the LOCK position unless the linkage is in reverse (for MT) or park (for AT).
Old Nov 15, 2012 | 06:34 AM
  #56
TenMidgets's Avatar
Congratulations! You've got some work ahead of you, but I really like the car...
Old Nov 15, 2012 | 07:05 AM
  #57
allyolds68's Avatar
What did it look like up on the lift? Post some video of that
Old Nov 15, 2012 | 02:17 PM
  #58
harlequin's Avatar
'70 442 Convertible
heres some pics. I plan on doing a frame off resto and I plan on keeping the car forever. Yes there was rust issues on the lower edges of body, but thats expected. Frame was rusty, but no holes. Engine number matched the Vin. Last time she was on the road was DEC 01. She wont be delivered until late Dec, because I'm having them do a few things to it. Everything worked except the rear backing lights, but that no biggy. I'm pumped, cant wait to get started on this project!
Old Nov 15, 2012 | 02:19 PM
  #59
harlequin's Avatar
'70 442 Convertible
the front brakes were drums
Old Nov 15, 2012 | 02:22 PM
  #60
gearheads78's Avatar
car guy
Congrats!!!
Make sure to start a build thread in our projects section.
Old Nov 15, 2012 | 02:30 PM
  #61
harlequin's Avatar
'70 442 Convertible
I will for sure. Heres some other cars he had for sale
Old Nov 15, 2012 | 02:48 PM
  #62
TenMidgets's Avatar
Is it me or does he have '69 looking hoods on those first two '70 442s?
Old Nov 15, 2012 | 03:21 PM
  #63
Magna86's Avatar
I want a garage like that one day! :-) Good luck on the new project. Looks like a decent start on a rare car.
Old Nov 15, 2012 | 03:22 PM
  #64
815Cutlass1972's Avatar
" Hoo yah "
Nice buy! Good luck with the resto.
Old Nov 15, 2012 | 03:26 PM
  #65
harlequin's Avatar
'70 442 Convertible
Thanks guys! It'll keep me busy!
Old Nov 15, 2012 | 03:39 PM
  #66
harlequin's Avatar
'70 442 Convertible
Here's the full VIN for those of you that wanted to see it, 344670E122522. Couple more pics
Old Nov 15, 2012 | 04:20 PM
  #67
Well at least it's a real 442 by the VIN. That wheel opening pic looks like it has fibreglass and bondo.
Nothing on the car that can't be restored with time and $$$$$$$$. Callous as it sounds, it looks to me like this guy was into appearance only. No effort made to restore anything underneath. Looking forward to your build.
Can you post a pic of the cowl tag when the car arrives?
Old Nov 15, 2012 | 05:19 PM
  #68
harlequin's Avatar
'70 442 Convertible
I'll post more pics of stuff when she arrives.
Old Nov 15, 2012 | 05:38 PM
  #69
The Bug Man's Avatar
The car has definite potential but that engine bay tells a lot. Some of the car looks way too nice to have an engine looking like that. It's kinda like some of my dates back in the day. If you rub and scrub the make up off what you really have may surprise you. All in all it looks pretty good and hey.... drop top 4 speed 442's don't come along every day Good luck to you and enjoy it !
Old Dec 31, 2012 | 03:50 PM
  #70
harlequin's Avatar
'70 442 Convertible
Got the car today! Here's the cowl tag Allan R
Old Dec 31, 2012 | 03:51 PM
  #71
harlequin's Avatar
'70 442 Convertible
Old Dec 31, 2012 | 03:53 PM
  #72
harlequin's Avatar
'70 442 Convertible
Here's me on the right with the dealer Roland
Old Dec 31, 2012 | 04:10 PM
  #73
Texas442's Avatar
1971 442 conv
Nice. Good car to restore.
Old Dec 31, 2012 | 04:21 PM
  #74
harlequin's Avatar
'70 442 Convertible
thanks man. looks pretty good from afar, but let me tell ya, after looking at EVerything..........she needs work.
Old Dec 31, 2012 | 04:26 PM
  #75
pogo69's Avatar
morgan
Be CAUTIOUS when dealing with New England 'old yankees'
Old Dec 31, 2012 | 04:28 PM
  #76
harlequin's Avatar
'70 442 Convertible
bahaahaaa! yea, i know what you mean! I think it was a good buy though for what it is. I've been looking for a project for awhile and this one fits my criteria. Do you know Roland?
Old Dec 31, 2012 | 04:36 PM
  #77
harlequin's Avatar
'70 442 Convertible
Its the Yangeese you have to worry about if you know your history
Old Dec 31, 2012 | 04:37 PM
  #78
pogo69's Avatar
morgan
No I don't...but I know a fair amount of old yanks from around here and they are very shrewd...nice looking car though, enjoy it
Old Dec 31, 2012 | 04:45 PM
  #79
sammy's Avatar
Sammy70 455 Supreme
Congrats on finding the car you wanted! 4spd,vert,442,70....yup, that fits my criterion for a nice project
Have fun with er....
Ted
Old Dec 31, 2012 | 04:48 PM
  #80
harlequin's Avatar
'70 442 Convertible
Thanks Ted, its a great way to start the new year!
