A.I.R lines broken off in cilinderhead
Old Jan 3, 2020 | 08:14 AM
Dogge's Avatar
Exclamation A.I.R lines broken off in cilinderhead
Dear people from classicoldsmobile,
First of all, happy new year for all of you! I am Jeroen from Belgium, i have a 87 Chevrolet Caprice with an oldsmobile 307 with the 7a heads. Today i removed all the A.I.R stuff etc. But the bolts of the lines at the cilinderhead broke off. Allmost every one. What can i do best about it? Can i drill in there or is there gonna fall metal in the engine?
Greetings
Jeroen Dogge
Old Jan 3, 2020 | 08:28 AM
Oldsmaniac's Avatar
You can drill there, its the exhaust side so nothing should go into the engine.
Old Jan 3, 2020 | 08:40 AM
Dogge's Avatar
Do you know the torque specs for the inlet manifold? I also have to replace the gasket. And ive read that it should be 40ftpounds but other people say thats way to much for a alluminium intake.
Greetings from Belgium
Jeroen Dogge
Dogge's Avatar
Thank you very much! Tomorrow i will start with it. I am glad that i can drill/tap in there!
Old Jan 3, 2020 | 08:57 AM
Oldsmaniac's Avatar
Jeroen Dogge
No I don't know the Torque specs. but you can probably find them on the internet for a 307 of your year engine.. I don't think 40ft lbs is excessive...
Old Jan 3, 2020 | 09:39 AM
OLDSter Ralph's Avatar
Jeroen Dogge
Maximum Torque is based on bolt size and grade. You'll not likely crush the aluminum, but you can strip threads on the bolt/stud or break them off if you use less than grade 5.
Find a picture of:
1. the torque sequence (order of torqueing bolts)
2. the correct torque specifications
3. whether the threads are dry or oiled.
4. washers ?
Old Jan 3, 2020 | 10:39 AM
Most aftermarket aluminum manifolds torque spec is 25# starting from the outside bolts working in.
Mred355
Mar 12, 2014 08:17 AM
805cut
May 11, 2012 11:09 AM
Rob delta
Dec 18, 2011 06:04 PM
Redog
Dec 7, 2011 09:47 AM
olds307owner
Nov 3, 2007 03:00 PM
