Column shift conversions
Old Jan 3, 2020 | 01:24 PM
Quo Lewis's Avatar
Has anyone ever did I conversation from a column shift to a floor shifter try to get rid of some of the linkage that was used to do it on my 83 cutlass
Old Jan 3, 2020 | 02:05 PM
svnt442's Avatar
The linkage is used to operate the neutral safety/backup light switch at the base of the column as well as allowing the lock to tuen back and the steering wheel to lock. If you installed an aftermarket shifter with it's own switches, you can disconnect to backdrive linkage and just zip tie the eyelet on the column up so that you can remove the key. If you go this route, be aware that the car can be turned off and the steering wheel locked while the car is moving.
richkidd24
Mar 22, 2018 06:50 PM
sheltonoil
May 19, 2017 08:37 AM
tbristol
Sep 8, 2013 12:28 PM
scott_442
Aug 10, 2011 06:17 PM
msco123
Sep 8, 2010 06:09 PM
