I need your help.
I need your help.
My father in law has bleesed me with a gift, a 1973 olds delta 88 convertible, it is an older resteration and still looks pretty good and runs great. My problem is it is missing the (female) portion of all the lap belts, story goes he hated seat belts and cut them out Can you point me in the right direction to find replacements.
With all due respect to your father-in-law, good God, what an $&%#. Couldn't he have just tucked them down between the seat bottom and back so they couldn't be seen? Did he really have to cut them out?
I had the exact same thing with my '67 Delta. A prior owner snipped the rear belts off at the mounting bolts. Had to remove all four bolts, and I got replacement belts from ebay.
I don't think you'll find new belts reproduced specifically for this car. Either find some from a donor car of the same year, or get something aftermarket. There's lots of choices out there if you're not after an OEM look. Again, ebay would be a good place to look if you want to try to find originals.
Guess you weren't around when the few who actually wore seat belts were laughed at as a bunch of kooks.
My family always did, because my grandfather had been an auto body man (tow truck driver - first on the scene) and an insurance adjuster, and had a raft of gruesome stories to tell, some from the era of plate glass windows.
In the fifties, he used to buy surplus airplane seat belts and install them in his cars.
As for the belts - get them at any junkyard that has older cars, or from a parts car - they should be near-universal through the GM range, probably even the same for big and small cars.
How many of you who bought these cars in non-restored condition, especially a few years ago, had to dig for the belts under the back seat cushions, or found them stuffed into the front seat crack? Most, I'd wager.
As for the reason why no lap belts, it's because the cars had no structural location high enough to mount shoulder belts on, and so were exempted from the requirement.
Unless you care about being original just order new Street Rod belts from a place like this. A lot safer than used belts that you don't have any idea if they have been sitting in the elements for the last 30 years.
http://www.julianos.com/seat_belts.html
I bought mine from this place:
http://www.seatbeltsplus.com/mm5/mer...-Lap-Seatbelts
jeffreyalman
October 6th, 2019 10:15 AM
Xavier777
February 24th, 2013 08:33 AM
gearheads78
March 1st, 2010 05:56 AM
