I Got a new fuel senging unit but the Resistance when Full is different
Hello!! This is my first post here
. Anyways I have a 1971 Cutlass S Holiday Hardtop and I just today put a new fuel sending unit it because I at least need an idea of where my gas is at. Is there a way to counter the extra 5 Ohms I gained with putting the new unit in? The original was 90Ohms and the new one is 95Ohms or is the difference on the gauge gonna be almost negligible because I know that 5 Ohms is fairly small. Thank you in advance
Here is the Unit I got: Fuel Sending Unit 692243
And ill have some pictures of the old Unit as well
If the gas gauge is linear with respect to resistance, then the extra 5 Ohms, which is probably a negligible difference, anyway, would cause the gauge to read slightly higher when full. If it was right on the F when full before, it'll be slightly past the F when full with the new gauge. If it was already slightly past F when full before, it will be a little further past F with the new gauge. Etc.
The gas gauge is just an Ohmmeter with zero resistance equal to E on the gauge and an open circuit (infinite resistance) equal to point on the gauge well past F, often the 3 o'clock position.
I wouldn't do anything other than put the new sending unit in and get on with life.
Thank you guys for the reply's i'm gonna just leave it alone
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
68RocketAction
December 18th, 2014 11:19 AM
help442onguam
March 20th, 2011 12:25 PM
