how much horsepower do i have?,
455,Bored. 40 over,mild cam upgrade.moter was rebuilt stock other than cam.moter came from a 71 delta 88.400 trans with v6 rear.stock q-jet carb.
So anybody know about what horspower i have .
The real answer is that real world HP will always be less than you think. The factory numbers were suspect at best (again, how did the AT W-30 motors make the same HP and torque as the MT motors, despite a much milder cam, or how did the Toro motors make more HP than the W-30 motors with a milder cam, more restrictive intake and exhaust, etc?). The only way to know for sure is to either put the motor on a dyno or run the car at the track and back out HP from your ET and vehicle weight.
http://en.wikipedia.org/wiki/Oldsmobile_442#1972
There is absolutely zero difference between a 1971 and a 1972 455 unless it was a 1971 w-30 car with H heads.
Some people were lucky and received heads with bigger valves. I have a pair of 71 442 heads here that were big valve models. With 8:1 compression, I imagine it helps, but not very much.
So what u know,i have the high compression. pistons.i can't see very much. but i can see its a bell shape , like the first high compression photo.
so now what does that tell us.
71 Cutlass
January 25th, 2022 10:12 AM
jkoester122
January 13th, 2012 02:48 PM
