Hot start issues
Old Jan 13, 2013 | 01:24 PM
Joe Hatton's Avatar
Hot start issues
My car starts great when cold, but after it warms up it won't start at all. It cranks just fine after it's hot...just won't start. Any ideas or redirection to prior posts are great. I have a 1972 cutlass with a fresh rebuild and brand new distributor ( standard points model).
Old Jan 13, 2013 | 01:39 PM
1970cs's Avatar
Lansing built
When it gets hot, do you have spark?
Pat
Old Jan 13, 2013 | 01:42 PM
If it is hard to start when hot, there are many things that cause this. I would start with the basics, and go thru my tune and recheck carb and make sure choke is pulling off. Also re-torque intake and carb bolts. What is your dwell, timing, idle speed set to?
If it won't start at all, then u need to check the big 3, air, fuel and spark. That is what is needed for a car to run.
Old Jan 13, 2013 | 02:04 PM
65B01Delta's Avatar
Coil ?
Old Jan 13, 2013 | 02:29 PM
m371961's Avatar
No spark, posible coil or condenser
sparks, flooding or no fuel
Old Jan 13, 2013 | 03:16 PM
Pat
What Pat said. We need more info to provide a useful answer. Since the engine turns over (presumably at the correct speed) the battery is fine. Next thing to check is spark and carb (fuel and choke). Is this a stock carb or an aftermarket? What type of choke?
Old Jan 13, 2013 | 04:42 PM
Lady72nRob71's Avatar
Does it eventually start after a few seconds more of cranking?
Old Jan 16, 2013 | 07:10 PM
Joe Hatton's Avatar
Thanks for all the input and sorry for late reply...damn work thing getting in the way again. I added a new coil and resistor- so far seems to have done it
The engine was a new rebuild with edelbrock performer cam, intake and carb.
I will hook up the electric choke this weekend, recheck the torque on manifold bolts and god willing be done for awhile.
Thanks again to all for the input, great forum
Old Jan 17, 2013 | 06:10 AM
m371961's Avatar
"I will hook up the electric choke this weekend"
If the electric choke was not hooked up, was it adjusted to stay full open?
If not, then engine was flooding when hot and I suspect problem not in coil.
Old Jan 17, 2013 | 09:32 AM
Joe Hatton's Avatar
Great info, overlooked that one. Well, the coil was original anyway and the $40 was cheap insurance for my teenager that will undoubtedly commandere (sp.) the car soon
Old Jan 17, 2013 | 12:00 PM
m371961's Avatar
Working on points and carborated cars has me overlooking things that I forget after so many years.
If your re-install the old coil and find it was not the trouble, keep it along with a known good set of points and a condenser in the car. I always did that on point cars.
For 70 and 80 GM HEI cars, I kept a spare rotor.
For 70 and 80 Fords, ignition module
Don't know what to carry for 90s to 2010 cars.
Don't own any 2010 and up cars.
Old Jan 17, 2013 | 05:05 PM
AAA and a credit card with a large limit!
Old Jan 17, 2013 | 06:18 PM
Rickman48's Avatar
Find a good body shop before you let a teenager drive it, too!
Not to mention good insurance.
Old Jan 18, 2013 | 06:40 PM
Joe Hatton's Avatar
Funny. unfortunately I am the body shop too. Any kid turning wrenches is all good with me
Old Jan 18, 2013 | 08:22 PM
OLD SKL 69's Avatar
GM Enthusiast
Most of these original coils are toast by now and should be replaced, even for just some peace of mind.
New'n72
May 10, 2024 06:29 PM
Redog
Mar 18, 2012 09:21 AM
67Olds442X2
Jun 14, 2011 06:20 PM
Oldsproject
Jun 21, 2008 07:03 AM
kentg
May 3, 2007 04:30 PM
