1991 delta 88 won't start when hot
Old May 3, 2007 | 04:30 PM
kentg's Avatar
my 1991 Olds 88 will stall (engine dies) after driving for 10 - 15 minutes or won't start after turning off engine. It will start after cooling down for a few minutes and run for a while again. The starter turns over the engine but won't start.
This started after the new fuel pump was installed. I checked the fuel pressure when it won't start and got reading of 35 - 40 lbs. I had a new coil pack installed. The engine runs very smoothly and easily passed the smog check here in Califonia just before the fuel pump was changed. The spark plug wires were recently changed.
Any ideas about which electrical component might be causing the problem?
stevengerard
Sep 10, 2014 03:17 PM
Redog
Mar 18, 2012 09:21 AM
bigAl455
Sep 13, 2011 02:47 PM
67Olds442X2
Jun 14, 2011 06:20 PM
Oldsproject
Jun 21, 2008 07:03 AM
