Help with AC
Old Jul 12, 2017 | 10:17 AM
70cutlassdb's Avatar
Help with AC
Hope all is well guys, its been awhile but I'm looking for info. I'm working on my AC, I have it running. However when I move the ac controller to high its stops blowing. But as long as I have it on medium it blows. Do I need to replace the switch or is it a different part I'm needing. Thank in advance for all info.
Old Jul 12, 2017 | 12:41 PM
hookem horns's Avatar
Welcome. There is a separate relay and in-line fuse along the firewall for the high speed setting so check those. Common problem so do a search for more info. Goggle often works better (include Classic Oldsmobile) than the search within the forum.
Old Jul 12, 2017 | 01:43 PM
High speed uses a separate power source from the medium speeds. The problem could be the fuse noted above, the relay that switches it, or the switch on the control panel.
Old Jul 14, 2017 | 02:22 PM
thanks for the info. I will check that
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
