Hello New Friends
Old Sep 25, 2025 | 07:55 PM
Dougger1957's Avatar
Hello New Friends
I had a 1967 Cutlass Supreme when I was attending college. It was actually in pretty bad shape, and I had to run the heater in the summer to keep it from overheating. It had a 330 CID engine with a three-speed transmission. Although the car was in poor shape, I loved the looks of it. Fast forward 45 years and I have bought a 1967 Cutlass Supreme Holiday Coupe. I am cleaning it up and fixing what needs fixing. It is gold with a black vinyl roof. 330 CID engine and a two-speed Jetaway transmission. All original with its original paint. Glad to be here.
Old Sep 25, 2025 | 08:55 PM
cfair's Avatar
Welcome. I have big cars, but you have my favorite year Cutlass/442. ‘67 was the peak to me. Clean mature design. The tail lights were a solid advance over ‘66.
There is a deep supply of repair and maintenance parts for these cars. Generically a ‘67 Cutlass is considered a GM “A body” meaning that they share some stuff with Chevelle, Skylarks, & Pontiac Tempest/GTO. So you can swap _some_ stuff. But not engines, not rear ends, and only limited trim.
Get the A body catalogs and websites, but consider 65-67 your key target years. In 68 GM went to the more popular teardrop shape (and then onto Collanade styling in ‘73) so start with 65-67 and fall back to other years for parts if you need to.
330/Jetway is a classic combination. Usually the advice here is keep the car original. I support that. But if, in your dreams, you really want a big block with a TH400 or 4 speed Muncie, I’d say go for it as an adventure. Those kind of changes take time and $, but if that’s where your head is, it’s part of the fun. I’m pretty much a purist and have left my big cars more or less stock, but here & there I kick around converting my Starfire to a modern manual 5 speed and have begun stockpiling the parts to make it happen someday.
Quick technical hits are upgrade to and HEI distributor if you want to avoid adjusting points and are willing to carry a spare HEI module in the glove box. An internally regulated alternator to avoid the firewall mounted voltage regulator is a good fix too. Disc brakes are a good safety change. 1967 drums don’t stop as fast as modern car discs do so every car ahead of you can stop shorter than you. When you drive leave stopping room ahead of you. If you carry passengers, consider adding middle seat seatbelts to protect them.
Warmly suggest that you focus on safety first. These cars are all but 60 years old now. They have lived lives long before you. Personally I start with tires, brakes, and suspension - if you know they’re good, you pretty much have the stuff that can kill you covered. Then I move onto reliability stuff - electrical, engine. Then I head for exterior paint, body, exterior trim. For me the final step is interior trim. Keep a fire extinguisher in the trunk and carry some tools. Put a jumper cable in the trunk too.
Myself excluded, the depth of knowledge here at C/O is fantastic. Dig in, read up and enjoy!
Cheers
Chris
Old Sep 25, 2025 | 10:00 PM
69CSHC's Avatar
↑ great post Cfair. Priority thorough.
I had similar issues with my first car a 330 3sp 67 Cutlass Coupe and she was in good shape. In my case it was likely the lack of shroud, followed by the 4 blade fan, followed by traffic. My first car back in 1980s and I really drove her.
Nice, welcome aboard.
Cfair covered it so well it's hard to follow up. But if you do decide to modify. Swapping the Jetaway to a TH350 will be the biggest bang for your buck bar none. Jetaways are missing a real first gear the difference between the two is 1 full second in performance. The equivalent of a 25 hp gain without touching the engine. Not to mention how much more fluid the car will be when mingling with modern traffic.
Old Sep 26, 2025 | 12:35 AM
Welcome
Old Sep 26, 2025 | 04:59 AM
Andy's Avatar
Welcome..pics of your new ride? I am a sucker for 66 more than 67 but hey that’s what makes this a fun hobby.. lots of knowledge and parts for sale on this forum for these cars.
Old Sep 26, 2025 | 05:20 AM
Welcome, we do like pictures.
Old Oct 2, 2025 | 05:30 PM
Cheers
Chris
First thing I did was tune the engine and then bought a new set of tires, coil springs and shocks. I bought octane boost to get the octane up to at least101 and some lead additive.
Old Oct 2, 2025 | 05:37 PM
The gages for the engine show the water temp does not exceed 180-190 degrees, even when sitting in traffic, and the oil pressure is 50 psi. The transmission shifts smoothly where it should shift. It accelerates smoothly but not a speed demon. I don't want a street rod, just a nice old Cutlass Supreme to cruise and drive the highway. It looks like I got it.
Old Oct 2, 2025 | 05:38 PM
Thank you
Old Oct 2, 2025 | 05:41 PM
Working on photos.
Old Oct 7, 2025 | 03:49 PM
Old Oct 7, 2025 | 07:23 PM
GCH's Avatar
GCH
Very nice car
Old Oct 8, 2025 | 04:46 AM
OHHH YEAHHH!
Old Oct 8, 2025 | 05:00 AM
Andy's Avatar
Boy that looks super clean.. beautiful car my friend
Old Oct 8, 2025 | 06:14 AM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! WOW, that's a beauty! Great color too. Hope you will post more pics.
Old Oct 8, 2025 | 02:11 PM
Tj Pal's Avatar
Very nice!
Old Oct 8, 2025 | 02:49 PM
More pics
Product photo of 1967 Oldsmobile Cutlass Supreme · S Coupe 2D
Old Oct 8, 2025 | 02:50 PM
More poics
Old Oct 8, 2025 | 02:52 PM
More pics
Old Oct 8, 2025 | 02:53 PM
More pics
Old Oct 9, 2025 | 07:46 AM
QMaster's Avatar
Nice car!
drum260
Jan 2, 2023 04:53 AM
wasjr1117
Mar 5, 2021 10:03 PM
babailey
Non-Olds Engines
Nov 19, 2020 07:32 AM
olds01
Sep 18, 2019 05:17 AM
ccnclassicoldsmobile
Mar 21, 2013 02:23 PM
