Fuel pump
Old April 7th, 2015, 05:40 PM
chadrickle's Avatar
Fuel pump
Hello - looking for some advice...I am currently building a 68 442 convertible. The engine is a 69, 455, bored 30 over, mild cam. Should I use a stock manual fuel pump or an electric one? It does have an HEI distributor.... Stock Quadrajet carb....
chadrickle is offline
Old April 7th, 2015, 07:35 PM
I'd use a mechanical.
oldcutlass is online now
Old April 7th, 2015, 08:17 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I would probably use a mechanical although I might step it up to an aftermarket pump with a little more output.
redoldsman is offline
Old April 8th, 2015, 08:39 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
X3 Mechanical. No need for electric with a mild build.
droldsmorland is offline
Old April 8th, 2015, 08:57 AM
oldsmobiledave's Avatar
This
http://www.robbmcperformance.com/products/olds550.html
oldsmobiledave is offline
Old April 8th, 2015, 09:29 AM
Octania's Avatar
Stock pump says 30 gph under pressure per rob web page.
1/4 mile in oh 15s let's estimate.
At 30 g/hr, and 0.0042 hrs/ race, that's only 0.125 gallons per race of delivery capability. A pint seems like maybe not enough to do that.
Depends on the car and whatnot I guess.
The rob pump appears to flow about 2x as much in general.
It does not say, but one assumes that the flow numbers were produced with a stationary lab setup, w/o the effects of sucking the fuel forward from a tank located 16 ft aft of the pump... against the effects of vigorous acceleration.
Octania is offline
Old April 8th, 2015, 11:12 AM
This is not a race car. Stock mechanical fuel pump will work just fine. Just make sure you get the right one - should have a return line on a 455.
Check this one at Supercars Unlimited to see if it fits your application.
Allan R is offline
Old April 8th, 2015, 12:24 PM
For around $20, Rockauto has a Carter pump.
http://www.rockauto.com/catalog/x,ca...,parttype,6256
Old April 8th, 2015, 03:07 PM
Only 2 left though... Also good that Carter is made in good ol USA.
Allan R is offline
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
sshriber
March 22nd, 2010 06:16 PM
Quick Reply: Fuel pump
