Erratic speedometer
Erratic speedometer
In my 72 olds, my speedometer was " bouncing and ticking" at lower speeds 0-40. I lubed the cable with graphite which did not seem to help. I then added some small dabs of graphite to the speedo components, now it is way worse and stuck on 120????
Any thoughts? Did I ruin the speedo...
Baaaad idea. Sorry.
Wow! So now your car is doing 120 all the time? Cool!
I bet that'd make my car go even faster than those chrome valve covers would.
But seriously, the internal mechanism of the speedometer is essentially the same as a clock - unless you rebuild watches for a hobby, you shouldn't mess with it.
If you put graphite inside of it, a professional instrument restorer can probably get i cleaned up like new, but it may be cheaper to just buy another unit.
If lubricating the cable doesn't correct speedo chatter, it's usually time for a new cable or core.
Vistabrat72
May 16, 2013 08:36 AM
