cowl trim code
Old Jun 13, 2016 | 09:20 AM
fredrick#44's Avatar
Question cowl trim code
I own a 1987 442 I have decoded most of the vin and cowl trim tag . but the last six digits of the vin are 309520, and the production sequence number is 049166 . it has 442 stamped on the cowl trim tag the vin engine code is 9 . on the rpo sticker on the trunk lid has F41,GT4,G87,LG8,MW9,N10,N83,QYH,U21,Y64,W42,CF5, duel snorkel air cleaner w/chrome lid and 120 speedometer ,one of 501 w/power sunroof just would like to know how to how to decode numbers.
Old Jun 13, 2016 | 09:54 AM
The last six digits of the VIN are simply the sequential serial number and don't "decode" to anything. The production sequence number is similarly a serial production sequence number for Fisher Body and also doesn't decode to anything.
Are you asking about the RPO option codes? If your real question is about the car being a real 442, it is. The VIN 9 motor was only used on 442s.
And unless the air cleaner snorkels are shooting at each other, that is a DUAL snorkel air cleaner...
Old Jun 13, 2016 | 10:51 AM
Thumbs up cowl trim
thanks for the help joe, as soon as I do a few more things to my 442 I will post some pictures , hope I can put video on here so u and others can here the aluminum headed 461 that took the place of the 307 . I know some people would not take the original engine out , ( it takes the originality from it) . Yeah but I have owned this car for 10 years and the owner before me did not garage keep this car . I've cleaned it up done some metal work , remember the 1st owner didn't care how he treated it his cousin tried to start refurbish it .but I bought it for $800 . anyway a 500HP @ 600LBS of torque big block beats out a 170HP 245LBS. 307 any day.
Old Jun 13, 2016 | 10:54 AM
I can't think of anyone who would complain about replacing a stock 307 with a 455.
Old Jun 13, 2016 | 11:12 AM
Talking duel
just got the shooting at each other hahaha I mean dual uh
Old Jun 13, 2016 | 05:51 PM
1970cs's Avatar
Lansing built
See if this helps you? http://mtupper.oldsgmail.com/rpospecs.htm
Pat
Old Jun 15, 2016 | 08:28 AM
Originally Posted by 1970cs
Old Jun 15, 2016 | 08:52 AM
cowl trim
thanks pat for the help my RPO decal has all of the highlighted codes. A51.BD2.B99.C60.D55.D85.GT4.G87.LG8(9code 307).NP5.N10.N83.QYH.TL6.U21.VT5.VO8.W42.Y64.12L.1 9U. only bad part is factory with out the G80 limited slip diff. but I replaced it with a aftermarket pro series diff and CF5 . mine is one of the 501 fact PWR sunroof 442s . does the U21 code indicate the 120mph speedo
jaunty75
May 29, 2015 04:16 PM
71OldsCool
Jun 20, 2014 06:11 PM
tmaleck
Sep 7, 2012 09:27 PM
Oldsmobomb
Mar 23, 2010 10:03 AM
rrielley
Feb 9, 2008 10:43 AM
