Confusion On Several Fronts
Where does the coolant overflow jug mount on a '70 442/W30?
Same '70 442. The lights in the "accessory" gauge on the instrument panel (water temp, oil pres., etc.) are REALLY dim. At first they didn't work at all. I messed around with the little ground straps (cleaned, reattached, etc.) between that gauge and the speedo. No luck. I then ran a hard ground to the battery and connected it to 1 of the screws that hold the instrument housing to the face (back of gauge), and got intermittent light. Off & on based on the position of the gauge. I then ran a second hard ground wire to the other screw holding the gauge together on the back. I have lights in the instrument now, but they are so weak that they offer no help at night. The other 2 gauges light as they should, when they should. Anybody have any ideas?
I appreciate any help, as I'm sure there will be further confusion in the future!
On the coolant jug, your answer is what I expected. Been looking at photos of high-end restorations and haven't seen one yet.
I'll check those connections. Hadn't thought about the hot side. 99 44/100% of the time, it's the ground!
Thanks for the help!
You can also take the gauges apart, takes a bit of time and patience, but repaint the inside with a fresh coat of light blue and the gauges will be birghter, along with new bulbs.
No cooling jug as others have mentioned
oldspackrat
March 5th, 2012 06:16 PM
