Cleveland ohio Checking in.
Old Jan 6, 2014 | 06:13 PM
djchunter's Avatar
Hey guys, I'm Dave from cleveland ohio, I have a 69 442 455 4spd car that I am getting ready to put under the knife here shortly. Its a non original drivetrain car, body is coming off and I am going to do the frame at the same time. Hopefully this summer it will be slammed on the ground with big brakes and EFI. Also if anyone has any advice on to were to buy the best quality rear quarters I am all ears. here's a pic from the day I picked up the car, I will have more up shortly. Thanks
Dave
Old Jan 6, 2014 | 06:22 PM
djchunter's Avatar
Old Jan 6, 2014 | 07:07 PM
Cool project.
Old Jan 6, 2014 | 08:45 PM
Keegan's Avatar
Hello from Louisville! (Near Canton, not the KY one)
Looks like an awesome project! What's under the hood now, since you said it wasn't original?
Old Jan 7, 2014 | 02:34 AM
Kennybill's Avatar
Hello Fellow Buckeye, I'm in Braceville near Newton Falls. The 1969's are great looking A-bodies. Good luck with your car. Ken
Old Jan 7, 2014 | 02:36 AM
ohiocutlassparts's Avatar
Dave from Dayton ohio good luck with your car
Old Jan 7, 2014 | 03:51 AM
djchunter's Avatar
Thanks for the welcomes guys. The motor is a 73 455 with c heads comp 280 cam long tube headers big oil pan and a scatter shield. I am going to convert to hydraulic clutch also. When I bought the car all the clutch linkage and pedals were botched although its an oridinal 4spd car. I purchased all the repo clutch pedal and linkage to find out that the later block isn't cast for a pivot ball. I ended up making a bolt on bracket and welded the pivot ball to it so it all works and drives now lol. But its not right so I think im just leaning towards hydraulic.
Dave
Old Jan 7, 2014 | 04:27 AM
eric66's Avatar
Hello from Canton ,OH
Old Jan 7, 2014 | 05:24 AM
chadman's Avatar
Welcome. I am from Wakeman (about 40 minutes West of Cleveland). The whole slammed with big brakes and wheels thing isn't my cup of tea but I do love '69's!
Old Jan 7, 2014 | 05:35 AM
rjohnson442's Avatar
Mr. Johnson
Grew up in Cleveland, I live in Massillon now. Welcome and enjoy the ride.
Lots of Ohio Love on here lately.
Old Jan 7, 2014 | 06:04 AM
citcapp's Avatar
Welcome form the left coast
Going to be a nice ride when done
Old Jan 7, 2014 | 10:01 AM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Grew up in Maple Heights moved to Detroit in 1969.I guess im stuck here ..You will enjoy the Forum.Great Information and a great group of people.
If you ever make it up to Detroit .Make sure you are dressed for it.Start with a Flak Jacket and layers .Its 39 Below Zero Today.
Ron
Old Jan 7, 2014 | 10:15 AM
1971 Supreme's Avatar
Cool project!! Just a little south of you in Brunswick.
Old Jan 7, 2014 | 10:55 AM
Welcome. The best quality rear quarters are good used OEM sheet metal. The only repros for the 69s are the poor-fitting Chinesium partial quarter panels. What's the story on the intake? It looks like an aftermarket plenum adapted to a single plane intake?
Old Jan 7, 2014 | 12:51 PM
djchunter's Avatar
I made it, ifs a offy dual quad lower, ls1 mid ram base that I had to cut the front flange out of and move for the correct spacing and topped it off with a Holley high ram ls1 plenum . Also added the injector Bungs and made the fuel rails out of rail stock.
I don't need full quarters just the lower section and the wheel wells. I planned on buying repo quarter and just using what I needed
Old Jan 7, 2014 | 12:57 PM
I made it, ifs a offy dual quad lower, ls1 mid ram base that I had to cut the front flange out of and move for the correct spacing and topped it off with a Holley high ram ls1 plenty . Also added the injector Bungs and made the fuel rails out of rail stock.
Very nicely done!
What's you plan for a controller?
Old Jan 7, 2014 | 03:45 PM
djchunter's Avatar
I am going to use a ls1 harness and computer. Aem make a dual sync sender that will mount to the distributor shaft that emits the correct24x crank and 1x cam signal. This way I can tune everything with hp tuners use the coil near plug setup and just change the pin at the ecm for the correct injector and coil firing order. Hp tuners has a tab in the software to change firing order so that the misfire and O2 feedback for the banks would be correct then after the wires are switched.
Old Jan 7, 2014 | 03:49 PM
djchunter's Avatar
I also thought about having a custom olds cam ground for the ls firing order since the crank throws are still the same. Its said that the New firing order reduces crank stress by up to 15%
Old Jan 7, 2014 | 04:48 PM
djchunter's Avatar
Here's a pic of the inside of the manifold where I modified it and how I mounted the fuel rails.
Old Jan 7, 2014 | 08:06 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Looks like a nice project.
Old Jan 8, 2014 | 01:51 PM
Magna86's Avatar
Nice job on that manifold. Way beyond anything I could do. Car looks pretty solid to start with and who doesn't want a manual car!
Old Jan 8, 2014 | 02:00 PM
501Paratrooper's Avatar
Nice ride, welcome to CO.
mat1227
Feb 3, 2016 06:38 PM
JMOOLDS
May 2, 2015 07:00 AM
4-Speed
Drivetrain/Differentials
Nov 19, 2010 04:54 AM
Bikedude
Oct 14, 2010 08:52 AM
wolfman98
Mar 8, 2009 04:14 PM
