Bought a 70 Cutlass last month
Old January 6th, 2013 | 09:07 PM
Erick's Avatar
Had a Holiday coupe in the early 90s and finally got one again. - Tons to do, but starting off with a good body.
Old January 6th, 2013 | 09:20 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Nice looking ride. What work do you need to do on it?
Old January 6th, 2013 | 10:10 PM
2blu442's Avatar
Welcome to the site! What part of the country/world do you live in?
John
Old January 6th, 2013 | 11:12 PM
Erick's Avatar
To Do List
> changed the heater blower motor
> need to replcae the speedo cable
> now trouble-shooting to determine the condition of the engine - https://classicoldsmobile.com/forums/big-blocks/58069-low-vacuum.html#post494280
> rear window has a small leak into the trunk / needs to be resealed.
> The upper air vents are not functioning. (fine for now in NJ, but I'd liek themn to work before July.
> The original radio is hooked up to only one speaker sitting on the floor under the passenger seat.
> tires are too short and dry rotted (235/60R14)
> the rear end is either an open differential or burned out (still need to test). I want a LSD and lower ratio diferential for use on the highway - although I'll see what taller tires in the rear do to lower RPMs.
> The carb is form a 1977 Buick... missed getting the correct 1970 carb from Ebay for just over $100 a coupel weeks ago. Maybe the 1977 Quadrajet is better than the 1970 because of the part throttle adjustment available on this later carb. I need to adjust the secondary opening (it bogs at the moment)
> In the early 90s I set up a 1970 cutlass suspension to HO-Racing specs (with 1977 camaro spindles up front, stiffer sway bars, new springs, new bushings) - It handled great! - would like to do that again and I still have a few of the parts.
> I have an MSD-6AL that was on my Cutlass a couepl decases ago, so I'll eventually add that.
> Need to add guages - I only have idiot lights. I've already added a bung in an exhaust pipe and have a wide-band O2 sensor to install along with a gauge - so I can monitor the air-fuel mixture under various conditions. A vacuum gauge and tachometer are next. - Then oil pressure and water temp.
> There is no underlay in the car. Instead of addingn the heavy stock tar paper, I expect to add dyna-mat or equivalent.
> The firewall is not sealed / I get excessive noise form the carb and engine compartment.
>... and the list goes on.
Old January 7th, 2013 | 07:53 AM
Rickman48's Avatar
Get the right carb!!
The '77 carb was for a low compression, unleaded gas, choked-up converter motor, and is set so lean, it may burn valves/pistons!
It'd be hard to get that to run right on a high compression motor!
And, judging from your other post, is the reason for 'pinging'.
Old January 7th, 2013 | 08:16 AM
MX442's Avatar
Only if it retains the original rods and jets. These are GREAT carbs if you know how to set them up for your application.
Nice car! Enjoy your project.
Old January 8th, 2013 | 08:35 PM
Erick's Avatar
Exactly what I was thinking - So on my list is to install a wide-band O2 sensor so that I can ensure I am not runinng too lean. I figured that the APT which is par tof the 1977 Quadrajet's repetoire will allow me to adjust part throttle air/fuel ratio bette rthan I coudsl with a 1970 carb.... although I must admit that there is a certain appeal to having a 1970 Olds carb on a 1970 Olds motor. and don't tell anyone, but except for the price, I wouldn't mind a Sequential port fuel injection system or even a TBI (MSD, Holley, Edelbrock, etc.) for increased performance throughout the year (power/economy/engine life).
By the way, you have a great looking driveway
Old January 8th, 2013 | 09:19 PM
1970supremevert's Avatar
Nice car.. factory color?? you have a PM
cutlassjoe
January 30th, 2019 05:52 AM
442much
August 20th, 2010 01:06 PM
MN71W30
February 20th, 2009 10:44 AM
