Bought a 70 Cutlass last month
To Do List
> need to replcae the speedo cable
> now trouble-shooting to determine the condition of the engine - https://classicoldsmobile.com/forums/big-blocks/58069-low-vacuum.html#post494280
> rear window has a small leak into the trunk / needs to be resealed.
> The upper air vents are not functioning. (fine for now in NJ, but I'd liek themn to work before July.
> The original radio is hooked up to only one speaker sitting on the floor under the passenger seat.
> tires are too short and dry rotted (235/60R14)
> the rear end is either an open differential or burned out (still need to test). I want a LSD and lower ratio diferential for use on the highway - although I'll see what taller tires in the rear do to lower RPMs.
> The carb is form a 1977 Buick... missed getting the correct 1970 carb from Ebay for just over $100 a coupel weeks ago. Maybe the 1977 Quadrajet is better than the 1970 because of the part throttle adjustment available on this later carb. I need to adjust the secondary opening (it bogs at the moment)
> In the early 90s I set up a 1970 cutlass suspension to HO-Racing specs (with 1977 camaro spindles up front, stiffer sway bars, new springs, new bushings) - It handled great! - would like to do that again and I still have a few of the parts.
> I have an MSD-6AL that was on my Cutlass a couepl decases ago, so I'll eventually add that.
> Need to add guages - I only have idiot lights. I've already added a bung in an exhaust pipe and have a wide-band O2 sensor to install along with a gauge - so I can monitor the air-fuel mixture under various conditions. A vacuum gauge and tachometer are next. - Then oil pressure and water temp.
> There is no underlay in the car. Instead of addingn the heavy stock tar paper, I expect to add dyna-mat or equivalent.
> The firewall is not sealed / I get excessive noise form the carb and engine compartment.
>... and the list goes on.
Get the right carb!!
The '77 carb was for a low compression, unleaded gas, choked-up converter motor, and is set so lean, it may burn valves/pistons!
It'd be hard to get that to run right on a high compression motor!
And, judging from your other post, is the reason for 'pinging'.
Nice car! Enjoy your project.
By the way, you have a great looking driveway
