Another Newbie
Another Newbie
I have a 70 cutlass convertible that I rebuilt and had almost ready for paint back in the early 90's
I replaced the engine with a high compression pull from a cutlass 442 version never got things tweaked.
Long story short a few yrs under a pine tree etc the car is need of another rebuild.
Including replacing the frame.
I found a Chevelle frame and started disassembling.
This time I am going to try to label things and not store all the bolts in the washer fluid reservoir.
I have all the original number engine tran etc and a 442 engine th400 and rear.
Looking forward to all the advice and info in this forum
Leaning towards the 442 config with the dual gate his and hers shifter.
I will be looking to identify the 442 rear end.
I will post pic hopefully tomorrow
Looking forward to all the info and advice
Welcome aboard.
Ha, that's funny as it is so true. I eventually learned to label all the parts with a description written on masking tape attached to the parts. Still somehow ended up with a spare part or two at the end of the build.
Welcome to CO. Try using Ziploc Freezer bags in quart and gallon size because they are heavier. Write bolt description/location on a parts tag and insert it in the bag. Use duct tape on seams for heavier batches in gallon size bags. AND take pics of things. Good luck.
d4nnyb0i
January 21st, 2020 11:32 AM
