91 olds cutlass supreme
Old Dec 2, 2013 | 04:50 PM
doby's Avatar
Question 91 olds cutlass supreme
This is the third time I have posted a request on this issue. maybe I'm doing something wrong. I'm looking for the trim that goes around the glass to roof/ Quarter panel. It is rubber with chrome in the middle. Kind of a channel trim. Can someone please help me out?
Old Dec 3, 2013 | 05:33 AM
1970cs's Avatar
Lansing built
A couple of issues first you need to go the parts wanted section. Second, I am afraid that after 1988 the crowd gets real thin that own/collect these vehicles.
Have you tried the W body forum?
http://www.w-body.com/forum.php
Pat
Old Dec 6, 2013 | 01:40 PM
doby's Avatar
Thank you 1970cs
Old Dec 6, 2013 | 01:49 PM
1970cs's Avatar
Lansing built
No big shakes! I hope you get better help over there! But don't let that be a deterent for sticking around, you never know someone here, may need your help!
Pat
Old Dec 6, 2013 | 02:22 PM
Your not doing anything wrong, but as stated most of us own older cars than yours and are not really familiar.
Old Dec 6, 2013 | 04:29 PM
CRUZN 66's Avatar
Olds Fever
Are you looking for all the trim or only one particular piece?
On the 91 Cutlass the trim you are looking for is comprised of four pieces…. The upper trim is a one piece design which goes across the top of both quarter glasses and across the back glass….. The GM part number for that trim is 10167396.… The lower trim is comprised of a left and right section with a center connecting escutcheon…. Each piece goes along the bottom of each quarter glass around the back glass meeting in the middle and connected with the escutcheon….. The GM part numbers are LH - 10109335, RH - 10109334, and the Escutcheon is 10130494.… A GM dealer may be able to do a parts search using the part numbers or you can do a Google search and may find something… Otherwise a salvage yard may be your best choice….
Check the link below…found with a Google search on one of the part numbers above….
http://oemcats.com/oem-parts/10109335.html
Hope this helps.........
Oldssupreme
Apr 3, 2015 08:36 PM
70olds455
Sep 11, 2011 03:52 AM
travisbeamon
Aug 7, 2011 12:51 PM
olds70supreme
Aug 1, 2011 05:22 PM
1967delta
May 1, 2010 06:16 PM
