84 cutlass won't start
Hey everyone, I had new plugs wires distributor cap and rotor put on the cutlass and let's say a not so professional mechanic mixed up the wires, I'd like to know if someone can tell me if the motor I have is original to the car so we can get the firing order correct, I'll send pics
yeah sure no problem
if hosting somewhere then poting a link here with the yellow rectangle icon is beyond your current skill set, you can send pix to a phone or email, right?
Check your VIN..... the 8th digit is the engine application for what is original to the vehicle......
A = 3.8 V6
V =4.3 V6 Diesel
Y = 5.0 V8
N = 5.7 V8 Diesel
9 = 5.0 (w/W40 Option)
A photo of what is currently in the vehicle would help to identify it.... If you are sure it is an Olds engine check the number and/or letter on the head as well as the casting number near the oil fill tube just below the front of the intake....
A = 3.8 V6
V =4.3 V6 Diesel
Y = 5.0 V8
N = 5.7 V8 Diesel
Wouldn't the firing order for all Olds 350's and 307's be the same? Isn't the firing order on the intake manifold? Now if it is a V-6, that is another story. V-8 or V-6 would be a good starting point.
We should start with is it a Brand C or O or a V6 or what?
Plus remember the installer has to know what direction the distributor rotates, how to tell if TDC is ready to fire #1 or some other cylinder, all that rot.
Got the 84 Cutlass started
sorry for the super late next year reply, we got it started, it is a V6.
oh and a tip for all the DIYers, NEVER EVER buy a BWD distributor cap for your car. the connectors break off with the slightest pressure on the plug boot.
