72 Cutlass automatic to 4-speed, won't start
Old Apr 24, 2012 | 08:00 AM
Paul Deckon's Avatar
Dad's Olds
Unhappy 72 Cutlass automatic to 4-speed, won't start
Have converted to a 4-speed, car turns over with spark and it is getting gas. Started once am died. Now will not start. Have I missed something in the wiring or does something need to be added.
Old Apr 24, 2012 | 08:03 AM
fourtwenty's Avatar
Neutral safety switch maybe?
Old Apr 24, 2012 | 08:10 AM
Dad's Olds
neutral safety switch
is still engaged on steering column and car turns over with spark that can't be it, can it?
Old Apr 24, 2012 | 08:12 AM
Dad's Olds
neutral safety switch is still engaged on steering column and car turns over with spark, that can't be it can it?
Old Apr 24, 2012 | 08:52 AM
Rickman48's Avatar
Pull a plug - if it's wet, change them all!
Old Apr 24, 2012 | 09:20 AM
It's not the neutral safety switch as the car turns over! Do you have 12v at the + side of the coil when cranking? And with the key on? Spark (at the right time), fuel, and air is all it needs to start and run.
Try holding your foot to the floor while cranking and see if that works.
stevengerard
Sep 10, 2014 03:17 PM
71ray
Apr 12, 2013 09:59 AM
Jonmueller1
Jan 29, 2012 06:59 PM
Salmonking
Jun 14, 2011 10:20 AM
stingjim
Apr 4, 2011 03:01 PM
