71 455 olds 98 newbe perf questions
Old Oct 2, 2009 | 09:02 AM
526 turbo's Avatar
hi guys thx for the site. my cousin has a 71 98 455 olds. 2 dr, he is looking to get gears for it or change the rear end out completely. he has 1 of the industrial rear ends, he was told u can get gears 342 from a certain year only to swap them out. can any body let me know where he can get a uaed set or what other complete rear end can he swap it out with. he has to stay with the same size lenght due to fender skirts and frame rails. 1 more question, any body have any hi perf motor parts for sale, cam lifters (rv) manifold, hei springs push rods. thx rob
Old Oct 2, 2009 | 09:06 AM
71 Oldsmobile 98s are AWSOME! To find a rear end for that car will be a bit more difficult than finding one for a Cutlass. Any 98, Delta 88, or Custom Cruiser from 71-76 would swap in without modifications. He might want to check out a Custom Cruiser in a salvage yard, they were probably more likely to have a posi-traction rear end since they would be used for towing and hauling. Finding a good used part is the problem since the B/C bodies aren't as popular as the A body. I don't know of any aftermarket suppliers that do parts for these cars.
Old Oct 2, 2009 | 10:08 PM
526 turbo's Avatar
thx stock car ran 15.20 in a 1/4 mile only in 2 gears, with 2.70 gears. do u know which model of gears can be swapped out. heard 3.42 is the only gears that can be, but were not sure out of what thx
Old Oct 3, 2009 | 04:44 AM
70 cutlass s's Avatar
There are lot of gear sets that work in that rear end. If the only thing your going to do is race it I would go lower than 3.42 more like 3.73, but if your going drive it daily. I would rather have 3.08 or even 3.23 with a spool or a locker.
Old Oct 3, 2009 | 07:21 AM
Oldsguy's Avatar
Past Administrator
We have a member who goes by Monzaz. He knows just about everything you would want to know about differentials, including the type O. Give him a shout if you need any more info or help.
Old Oct 3, 2009 | 10:15 AM
526 turbo's Avatar
thx can u post his user name so I may contact him. or pm me
Old Oct 4, 2009 | 04:16 PM
His username is:
monzaz
Like Oldsguy said, he knows everything there is to know about differentials.
FWIW, I don't think you will be able to easily find gears for your 98. I don't believe you can swap gears from an A body into a B or C body. I think the differential is different.
BTW, If you put 3.73s into your 98 it will be a dog on the highway (and that is just sacrelige for a 98). If you want to race exclusively then you should look into buying an A body. B and C bodies are cool, they just aren't built to race. They are built for crusing.
Old Oct 4, 2009 | 09:18 PM
526 turbo's Avatar
no just need a set of 3.42 is what I was told will work from a rivera from a certain year only. can anybody confirm this
Old Oct 15, 2009 | 11:13 AM
1ATony's Avatar
Welcome to the site.
bigblockolds
Dec 12, 2013 09:49 AM
Run to Rund
Nov 18, 2010 08:21 AM
442 Guatemala
Jul 24, 2007 11:51 PM
455nova
Feb 20, 2007 12:00 PM
