‘70 cutlass conv.
‘70 cutlass conv.
Hello all!!
I’m in my third year of my restoration and am working on the differential and desire to put a non-slip in.
I’m looking for some good reading material and recommendations on what gear ratio to install. I’ve beefed up the engine with a 10-3/4:1 cr and the turbo 350 has been rebuilt to handle the additional HP.
I don’t really want to pull the body off the frame, but am willing to if ya’ll think it is best to remove the rust from the frame. I did the front part of the frame when I pulled the engine-trany.
I like the original look, but want to beef up the suspension. What makes sense to keep and what makes sense to restore, I.e. the control arms etc. I’m Leary of doing the differential rebuild myself so any input on this would be great. Some reading materials on overall retoration would also be helpful. Thanks for all your knowledge in advance.
Welcome to the site. Your questions are kind of all over the place. Was the rust on the front part of the frame bad enough that you think it may be a structural problem or a potential one on the rest of the frame? If not only remove the body and
clean the frame if you want a show car.
We need to know your driving habits before recommending a rear end ratio.
Below is info about the O-Type that I copied from Brian Trick many years ago:
O-Type 12 Bolt
Here is a list of the posi units & what gears they will fit:
#673 = 2.56 & 2.78 ratios, 28 spline
#671 = 3.08 & 3.23 ratios, 28 spline
#588 = 3.42 & anything numerically higher, 28 spline
#672 = 3.42 & anything numerically higher, 31 spline
***The 31 spline axles were offered in late 67-68 OAI cars only.
Today, the only aftermarket O-Type gears are 3.42, 3.90, and 4.10 and they are made to fit the 671 series carrier. Here's a link to Richmond Gear's catalog. There may be other companies making them now, but I don't have that info.
https://www.richmondgear.com/wp-cont...n1.pdf#page=31
There is also a limited slip diff that is a Ford 8.8" carrier that is machined to fit the O-Type gears and housing, and I think it fits only the 3.08-3.23 series gears.
If you have an O-Type and plan on keeping it, you should contact monzaz (Jim Mitschke of JD Race) or 507olds (Brian Trick) as they are our resident differential experts and have intimate knowledge of them and parts for them.
66olds98conv
Ninety-Eight
March 21st, 2013 12:52 PM
Flgaurban06
Cars Wanted
September 21st, 2012 06:36 AM
The_German
August 28th, 2011 08:18 AM
