70 442 4spd Post w-30? from Valley of the Sun
Old May 10, 2015 | 10:36 AM
Black&White's Avatar
Just bought a 70 442 4spd Seller claimed original w-30 but had no proof. Has repop inner fenders, And engine vin is the same as the car expect for the first number of the vin. The trans has been replaced but it has a TO rear with 4:33's. Its a F block with F heads and the early w-30 intake.
TRIM TAG READS
ST70 34477LAN309259 BDY
TR 937 19 19 PNT
12A
VIN 344770M214102
OPTION ARE: Bucket seats, Console, Hurst Shifter, Manual front discs, 4 core rad, boxed control arms rear sway bar, OAI hood with correct air cleaner, rear wing it appears to be factory installed on the trunk. Not sure how to tell if it is and original w-30 without paper work. I bought it knowing it was a 442 if its a w-30 that would be a plus.
Old May 10, 2015 | 11:14 AM
tru-blue 442's Avatar
Old School Olds
Welcome. Post some pics when you can. Sounds like a nice one.
Old May 10, 2015 | 12:36 PM
TRIM TAG READS
TR 937 19 19 PNT
12A
VIN 344770M214102
I don't know what you mean by "the engine VIN is the same as the car except for the first number". The first number of both will always be a "3" to signify Oldsmobile Division. Your car does sound correct as an early Dec W-30, but the repop inner fenders always make me pause. Of course, unless you can find a build sheet or broadcast card, there is no other way to prove it's a real W-30.
Old May 10, 2015 | 12:49 PM
Joe, The first # of the last six vin sequence is not correct. The last five #'s on the engine stamp match the vin. The first three are 30M.
Old May 10, 2015 | 12:59 PM
Yeah, that sure sounds like a factory mistake. The odds of a replacement block being one digit off are far less likely than a factory mistake.
Old May 10, 2015 | 02:40 PM
Where are most build sheets found on a Lansing built car?
Old May 10, 2015 | 03:14 PM
In the trash can at the end of the assembly line, unfortunately.
You are far more likely to find a Fisher Body broadcast card, likely inside or under one of the seats.
Old May 10, 2015 | 03:52 PM
442Fred's Avatar
If this is the car from Tucson it has been gone through by several knowledgable people and nothing found.
I have seen it several times and it appears to be a real W car but no documentation to prove it.
Old May 10, 2015 | 05:23 PM
Yes, this is the car from Tucson. Good to know its been gone thru already. I thought the previous owner said that he looked for one but I don't know where all he looked.
Old May 10, 2015 | 05:41 PM
66trakpak's Avatar
I believe this car was discussed on here before. Is it the one that someone put a external voltage regulator on?
Old May 11, 2015 | 12:51 PM
Yes, is there anyone here in the Phoenix metro area that knows w
-30s that can look at my car and tell me what other things are wrong or missing ?
jensenracing77
Jan 11, 2022 03:01 PM
cessna195
Sep 5, 2010 09:16 AM
vettemad
Mar 27, 2010 05:34 AM
we jeep inn
Feb 20, 2010 07:19 PM
OldsMotion
Feb 6, 2010 10:14 AM
