70 442 4spd Post w-30? from Valley of the Sun
Just bought a 70 442 4spd Seller claimed original w-30 but had no proof. Has repop inner fenders, And engine vin is the same as the car expect for the first number of the vin. The trans has been replaced but it has a TO rear with 4:33's. Its a F block with F heads and the early w-30 intake.
TRIM TAG READS
ST70 34477LAN309259 BDY
TR 937 19 19 PNT
12A
VIN 344770M214102
OPTION ARE: Bucket seats, Console, Hurst Shifter, Manual front discs, 4 core rad, boxed control arms rear sway bar, OAI hood with correct air cleaner, rear wing it appears to be factory installed on the trunk. Not sure how to tell if it is and original w-30 without paper work. I bought it knowing it was a 442 if its a w-30 that would be a plus.
TRIM TAG READS
TR 937 19 19 PNT
12A
VIN 344770M214102
TRIM TAG READS
TR 937 19 19 PNT
12A
VIN 344770M214102
TRIM TAG READS
TR 937 19 19 PNT
12A
VIN 344770M214102
Yeah, that sure sounds like a factory mistake. The odds of a replacement block being one digit off are far less likely than a factory mistake.
If this is the car from Tucson it has been gone through by several knowledgable people and nothing found.
I have seen it several times and it appears to be a real W car but no documentation to prove it.
