69 cutlass s electrical problems
Old Jul 22, 2015 | 09:43 PM
Shocker41's Avatar
69 cutlass s convertible electrical problems
When either door is open do the rear side panel courtesy lights come on? Or do they only come on when you turn head light **** to the left?
Mine only come on when **** is turned. If they are suppose to be on when door is open any suggestions how to make that happen?
Also at random times like when I shift gears turn on blinker or turn on headlights it turns my radio off and on. I have checked the a couple of ground wires and they all seem to be ok. The radio turns off for 2 seconds then right back on again. Any suggestions???
Old Jul 23, 2015 | 05:02 AM
Welcome to the site, share some pictures of your car. There are pin switches that supply a ground to your lights at the front of each door jamb. The radio problem may be a bad connection or chafed wire under the dash around the steering column.
chasman414
Jun 25, 2020 07:05 AM
NMcCarthy
Nov 14, 2014 08:13 AM
FlyingV5150
Dec 24, 2013 01:36 PM
1968Cutlassfallbrook
Apr 20, 2011 12:56 PM
bpnoel
Aug 27, 2010 08:11 AM
