68 Cutlass will not start
Old Oct 11, 2014 | 10:58 AM
mrbones's Avatar
I turn the key and nothing happens. The battery is fine, lights work, radio works etc. etc. Checked the connections to the starter..all looks in order. What do I do?
Old Oct 11, 2014 | 11:11 AM
Welcome to the site, there is a purple wire to your starter solenoid, see if there is voltage there when the key is turned to start. If there is then you probably have a bad solenoid, if not look at your neutral safety switch connections or adjustment.
Old Oct 11, 2014 | 10:03 PM
64Rocket's Avatar
That's my thought also on the neutral switch. may need an adjustment.
Gene
Old Oct 12, 2014 | 05:30 AM
Try pushing the gear selector up past the PARK position while turning the ignition key to START.
Old Oct 12, 2014 | 05:32 AM
He can also try moving the shifter around in the Neutral position.
colemane
Apr 13, 2013 01:19 PM
Freddy B
Apr 9, 2012 06:25 AM
Destructor
Oct 22, 2010 05:35 PM
rrielley
Sep 1, 2008 03:00 AM
D Appeldorn
Apr 24, 2007 12:52 PM
