68 Cutlass S 350 V8 - I got nothin'! HELP!
Old Sep 7, 2010 | 01:48 PM
jonnyci's Avatar
OK, so a few weeks back I tried to jump start my 1968 Cutlass and I couldnt get it to do anything. The battery wouldnt take a charge either. So yesterday I went and got a brand new battery and still get nothing. Not even the starter click. I get the interior lights and the buzzer, but when I try to start it, the lights go extremely dim, to nearly out and nothing happens. Where should I start to look for the short?
Thanks!
Jon
Old Sep 7, 2010 | 06:53 PM
OLD SKL 69's Avatar
GM Enthusiast
I would check the battery cables. If they are old, they could have internal corrosion and could cause the exact problem your talking about. Also, check the mounting location for the negative cable and where it attaches to the engine. It could be loose or dirty.
Old Sep 7, 2010 | 09:11 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Be sure and check to engine ground. At that age I would start cleaning all the connections. How long has it been since it was started? I guess it could also be a starter but I am betting on the connections.
Old Sep 8, 2010 | 05:39 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. Cables...
Old Sep 8, 2010 | 09:29 AM
jonnyci's Avatar
Thanks for the info. I started to look at the ground connection briefly and found that it is still connected to the engine block. But I will do the necessary clean up of all the connections and go from there.
Jon
Old Sep 9, 2010 | 11:55 AM
jonnyci's Avatar
I am so glad I found this forum. You guys nailed it! Though it was a simple cause and fix, I would have never thought of it being that quick. I wish they were all that simple.
THANKS!
Jon
Old Sep 9, 2010 | 11:57 AM
Welcome
Welcome aboard
I'm glad ya got it fixed so quickly
Tedd Thompson
Oct 7, 2014 07:59 AM
rayfrausto
Jul 14, 2011 02:58 PM
84oldsDelta88
May 16, 2011 05:50 AM
exmoparluver
Ninety-Eight
Apr 14, 2009 09:31 PM
chip_gikey
31
Jul 3, 2008 06:47 PM
