67 Toronado and 455 engine block question?
Old Nov 15, 2012 | 06:04 AM
Texas Toronado's Avatar
Hello, I'm new in town and have a 67 Toronado (My original first car from my teens) and just purchased a 54 Hudson Hornet (4 door) with what I'm pretty sure is a 455 Olds motor.
The block number is N668482 and was wondering if someone could direct me to a website to identify the motor?
There is a slim chance that it's not an Olds but from all info I have and a couple old hot rod eyeballs that seems to be the consensus.
Any help is appreciated.
Thanks, Barry
tubb@mac.com
Old Nov 15, 2012 | 06:11 AM
2blu442's Avatar
Welcome to the site Barry! Those numbers don't sound familiar to me, but here's a thread showing where to located the casting number and if the engine is 1968 or newer where the vin would be stamped. If this doesn't answer your question could you post some pictures for us?
https://classicoldsmobile.com/forums...s-engines.html
John
Old Nov 15, 2012 | 06:20 AM
A photo of the motor would remove all doubt.
A 455 in a Hudson Hornet sounds pretty cool, though... I'd keep it just like that (well, maybe channel it onto a Jag XK16 chassis... ).
Old Nov 15, 2012 | 07:08 AM
Tedd Thompson's Avatar
Berry welcome aboard
Like the others have said a picture is worth a thousand words.
I'm an old Hudson fan with 53's being my old high school car. A Hudson with a 455, what a sleeper thats gotta be loaded with a bunch of the cool factor, wished I could have done that in high school. ....Tedd
Old Nov 15, 2012 | 09:15 AM
Olds motor pic?
Old Nov 15, 2012 | 09:19 AM
54 Hudson
Old Nov 15, 2012 | 09:20 AM
rocketraider's Avatar
Oldsdruid
N prefix sounds more like a 65-67 425.
Old Nov 15, 2012 | 09:43 AM
That's definitely an Olds 425 with a Chebby carburetor.
I like the dual-circuit master cylinder in the '54 Hudson.
Old Nov 15, 2012 | 11:24 AM
Well, first I assume that "block number" is actually stamped on the cylinder head. That makes it a 65-67 motor.
Sorry, Eric, but that's a rookie mistake. The 1966 Olds Qjets used the side inlet. The carb in the picture appears to be a correct 1966 Olds setup, including the divorced choke on the intake. That makes the intake and carb, anyway, a 1966 piece, and I suspect the whole motor is a 1966 425.
Old Nov 15, 2012 | 11:27 AM
I meant to add to my prior post that you should locate and tell us the BLOCK casting number, located above the water pump, next to the oil fill tube. That will confirm what block you have.
I also like the, ah, creative t-stat bypass and heater hose routing on the water pump.
Old Nov 15, 2012 | 04:06 PM
Ooops. I had actually read about that somewhere, but forgotten.
That would be one of those early QJets with the round-stamped unit number and the funky diaphragm needle and seat, then, no?
Old Nov 15, 2012 | 04:11 PM
Thanks for all the help
I'm satisfied with the motor being a 66 model 425.
I'll get back with the other numbers to make certain.
Thanks again, smart bunch you Olds folk.
Old Nov 15, 2012 | 04:35 PM
Won't my 67 Toronado pretty much have the same exact motor except for the angle difference?
Old Nov 15, 2012 | 04:45 PM
copper128's Avatar
Lt. Buzzkill (ret.)
'67's used the side fuel inlet and divorced choke also.
Old Nov 15, 2012 | 05:08 PM
The divorced choke itself isn't directly relevant, since it was used through 1969 (or were there exceptions?).
Old Nov 15, 2012 | 05:23 PM
it's the manifold on the 67 Toronado that's at an angle correct?
TicTocTach
Jun 16, 2015 04:03 PM
waterzap
Jul 22, 2014 06:41 AM
TicTocTach
Feb 19, 2013 05:16 PM
TimKillinger
May 31, 2012 09:32 AM
