67 cutlass rebuild
Old Sep 22, 2014 | 11:22 AM
brianbeez67's Avatar
67 cutlass rebuild
Hey guys, started removing the heater duct work and all from my 67 CS, I removed the A/C evaporator and found out that spray foam was used as a sealant. The area is where the evaporator seals with the passenger side interior kick panel metal. Same area where cars with no A/C have the manual vent. Does anyone know of a gasket or such to go in this area to prevent water from filling up the passenger side flooring? Any and all help is great
Thanks Brian
Old Sep 22, 2014 | 12:24 PM
tmaleck's Avatar
Thanks Brian
Mine had that semi hard bead sealing. If you get the drain holes cleared and clean the junk out of the opening, should be fine.
tim
Old Sep 23, 2014 | 07:05 AM
Trying to figure out what you mean by "semi hard bead sealing" is that something I can buy pre-formed or permatex initially I was thinking once all together to try and put that windshield BUTYL tape in the opening ?
What are your thoughts
Thanks Brian
Old Sep 23, 2014 | 02:57 PM
tmaleck's Avatar
Thanks Brian
The stuff I'm talking about is black like caulk in consistency, but it dries hard. A thick permatex or body sealer (even thick rtv) should do the trick.
If you get the drain holes at the bottom of the evaporator opening clear, it should never be able to fill enough to get into the vent opening.
Tim
Old Sep 24, 2014 | 10:40 AM
I'll give it a try, forgot about those darn drain holes, THANX brian
Old Sep 24, 2014 | 11:55 AM
steverw's Avatar
Mine actually had a gasket, a dense foam rubber one that deterioriated to mush. I can see it was a thicker heavy gasket, i dont think anyone repops them. Ill make on from some dense foam weather seal gasket material i got at ?Lowes or Home Depot. Cant remember which, its approx 1" thick sticky on one side.
jensenracing77
Jan 12, 2016 02:02 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
crank.it
Drivetrain/Differentials
Apr 30, 2003 07:01 AM
