67 442 engine casting
Old March 13th, 2013, 04:38 PM
bend442's Avatar
I am looking at a 67 442. It has an engine with what appears is the casting number 390923E. This is based on a picture the current owner sent me. I was hoping the engine casting number would have been 390925E. Any thoughts. Also, the engine is metallic blue, not bronze ........ although it does have the 442 engine decal on the valve cover.
bend442 is offline
Old March 13th, 2013, 04:44 PM
bend442's Avatar
help with 67 442 engine ident.
bend442 is offline
Old March 13th, 2013, 05:29 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
The "3" is probably a "5" if your sure about the "E" which is 66-67. The number is above the water pump next to the oil filler tube. The heads should have a "C" and a "V2XXXXXG" stamped on a pad behind alternator or A/C bracket. More ID info here.
http://www.442.com/oldsfaq/ofblk.htm...0Block%20Block
Could have been repainted and those stickers can be purchased unless it looks like it been there awhile course valves covers can be swapped.
The cowl tag should have a "5V" unless it's a "Fremont CA" car like the pic and I don't know what it should have. One of mine is a CA built car.
67Olds442X2 is offline
Old March 14th, 2013, 07:06 AM
bend442's Avatar
I just posted a picture of the engine casting number to album ...... its called 442 engine. Could anyone tell me if this is a engine block for a 67 442?
bend442 is offline
Old March 14th, 2013, 08:02 AM
390925 E is the correct block casting for a 1966-67 442 (as well as a 1967 Turnpike Cruiser). There is no such casting as 390923 E, so that's just a mis-read. It's often difficult to accurately read the block casting number if there's crud or rust in the way. Also, since the numbers are just depressions in the sand casting cores, they can become distorted.
joe_padavano is offline
Old March 14th, 2013, 08:12 AM
I merged the duplicate threads. There really isn't any reason to ask the same question in multiple subforums.
Old March 14th, 2013, 10:21 AM
Navy P-3 FE (Ret.)
Yes. I just realized my block picture wasn't the greatest. I also mentioned what else to look for. You'd have to check julian dates if you wanted to match the block to the car and that's no guarantee.
Old March 14th, 2013, 11:02 AM
Trying to remember member
wmachine's Avatar
I know what you're saying, but I don't see where "date coding" the block (or any other part for that matter) makes it correct for the car. It won't be the original engine. Period. A '66-'67 block is correct. Period. An unspecific cast date doesn't make it any more or any less correct.
So how does putting into into a time-frame that it "could have been, but wasn't" put into a car more correct? Nobody has ever been able to answer that for me.
When they sold replacement parts, they didn't consider date codes.
You know I'm not picking on you, 442X. It's just that the date coding business has gone way out of reason.
wmachine is offline
Old March 14th, 2013, 01:31 PM
Navy P-3 FE (Ret.)
I understand, even if there was a date range is it 66 or 67.
olds4life
August 6th, 2009 01:45 PM
olds4life
July 15th, 2009 01:21 PM
paige_dart
November 12th, 2007 09:40 AM
novice57
September 26th, 2007 12:07 PM
perro
May 2nd, 2007 02:39 PM
Quick Reply: 67 442 engine casting
