59 fiesta wagon with 65 model 425
Old Sep 7, 2022 | 06:11 PM
Oldsshagginwagon's Avatar
Hey guys I’m new here so I’m not to sure how this works but I have a 59 Fiesta wagon with a 65 model 425 in it. I have ordered a Edelbrock performer intake and a 750 Holley vacuum secondary and electric choke. I’m wanting to convert it to dual exhaust with a good deep sound but can’t find headers anywhere. Any recommendations?
Old Sep 7, 2022 | 06:39 PM
66SportCoupe's Avatar
You won't find headers for it. Nobody ever made any. You can fab your own headers for it
Old Sep 7, 2022 | 07:06 PM
BobsFiftyEight's Avatar
Tool Freek
Welcome to the forum, I love the old station wagons, very cool car, post some photos of your car and project, we all will be waiting to see them.
On the electric choke Joe P. has a detailed wiring instructions and parts needed to install it correctly, search this forum for "electric choke wiring" Joe P. has it on a "sticky note", February 3rd 2020.
Bob
Old Sep 7, 2022 | 07:29 PM
Welcome to the site, post some pictures when you get a chance. As mentioned above, you're on your own with the headers.
Old Sep 8, 2022 | 03:39 AM
That must have been quite a undertaking- putting that engine in that car! I'll bet it's a great cruiser. Welcome!!
Old Sep 8, 2022 | 07:06 AM
These cars are not popular to restore or hot rod. You'll be hard pressed to find headers for a stock first gen Olds motor, let alone a swap that virtually no one performs. Either live with stock manifolds or build your own custom headers.
Old Sep 8, 2022 | 10:04 AM
That's bad@$$! Make sure you post pics STAT!
Old Sep 8, 2022 | 05:14 PM
Old Sep 8, 2022 | 06:10 PM
Soooo cool!!!!
Old Sep 8, 2022 | 06:37 PM
Does anyone have any recommendations on dual exhaust manifolds that I could make work?
Old Sep 8, 2022 | 06:51 PM
old80cs's Avatar
https://www.thorntonmusclecars.com/p...haust-manifold
Or they have SS tube manifolds as well, just check their website. Neat car, can’t say i’ve ever seen that model before.
Old Sep 9, 2022 | 06:11 AM
67OAI's Avatar
Old(s)GuysRule
Wow! What a sleeper. Welcome aboard and keep us informed of your progress. Lovin' it!
Old Sep 9, 2022 | 06:20 PM
Tj Pal's Avatar
Welcome! Really cool. Definitely one of a kind.
Old Sep 10, 2022 | 08:45 PM
Cutlass Fan's Avatar
I am assuming the manifolds you nave are the ones where there is a cross over pipe from drivers side to the passenger side. What Olds did when installing duels was to just block off the the cross over port in the passenger side manifold. There were no special manifolds for dual exhaust.
Old Sep 11, 2022 | 05:55 AM
That is not correct for the 1965-70 full size cars. The location of the steering box on those cars required a special driver side manifold for dual exhaust that routes the pipe up and over the steering box. The single exhaust manifold is a center dump.
Post photos of the steering box and linkage location. Do you need a center dump or rear dump manifold? I'm not really familiar with the 1959 cars.
Single exhaust driver side casting 384785
Dual exhaust driver side casting 384895
Old Sep 20, 2022 | 11:18 AM
Old Sep 20, 2022 | 11:19 AM
I know it’s not the best pic I’ll get a better one later
Old Sep 21, 2022 | 05:09 AM
OHHH YEAHHH! Lookin' good!😎
Old Oct 2, 2022 | 04:44 PM
She runs
File Type: mov
Old Nov 26, 2022 | 09:52 AM
Old Nov 26, 2022 | 12:13 PM
Rallye469's Avatar
Oh lord…that steering box is SO far back!
Most cars have the box way out in front of the engine.
Youre probably going to have to live with the log style manifold Joe showed.
But with a decent dual exhaust and nice mufflers you’ll have a nice little rumble.
Cool car BTW!!!
Old Nov 26, 2022 | 01:13 PM
Rear steer is a "feature" of the 1970-older Olds full size cars. That's why the factory designed those manifolds specifically to clear the steering box.
Old Nov 29, 2022 | 06:15 PM
So I’ve been talking to a local exhaust shop in town where I live. He is going to block off the crossover on my passenger side manifold and run duals for me or also talked about doing single exhaust but sizing up to 2.5 inch with a nice muffler. Either way I’ve got to fix an exhaust leak on the passenger side manifold. Any and all tips would be greatly appreciated. I think it is leaking around the gasket and also around the crossover.
Old Nov 30, 2022 | 05:04 AM
You can have an exhaust shop block off the cross- over port in your passenger's side exhaust manifold, or you can take it to a welding shop and have the cross-over port welded in permanently. While cast iron is difficult to weld, a good welding shop shouldn't have any difficulty in tackling that job for you. My father; Oldsguy, had cast iron Oldsmobile exhaust manifolds modified that way for a 69 Delta 88 he owned years ago.
You might also be able to have 2 exhaust pipes run down the passenger's side of the car if you can't find a rear dump driver's side exhaust manifold.
Old Nov 30, 2022 | 06:03 AM
VC455's Avatar
Barely Registered
Welcome to CO. What a great car! The engine sounds good too.
If it will help with your choice of exhaust...
A 2 1/2" single pipe gives the same back pressure as 2" dual pipes.
Old Dec 19, 2022 | 07:47 AM
pappy's Avatar
You can run single exhaust back to a dual outlet muffler, then dual it out from there. That is what I did on my '65 f85 Deluxe, and it's the best sounding "duals" I've ever had. I swear, this exhaust actually gave it a (at least a butt dyno) performance improvement.
Old Dec 19, 2022 | 11:09 AM
It's a scientifically proven fact that ANY improvements done to your classic car will result in better performance on the butt dyno.
Old Dec 19, 2022 | 04:04 PM
pappy's Avatar
Wink
True dat!
If it sounds faster, the butt dyno needle moves accordingly.
v8al
Vista Cruiser & Wagons
Oct 16, 2022 08:31 PM
ragtop olds
Jul 22, 2019 05:12 AM
Bamfer
Jul 1, 2014 05:54 PM
ankerclanker
Jun 17, 2014 10:43 PM
tailfins
Oct 12, 2012 10:02 AM
