55 olds 98 steering box what can be used to replace it for more room.
Old Nov 17, 2012 | 06:19 AM
dahl1car's Avatar
I have a 1955 olds 98 2dr. im in the process of putting in a 455 and dont have room for the stock power steering box. Is thare a box that some one has used to replace the stock one?
Old Nov 17, 2012 | 09:08 AM
dahl1car's Avatar
Thanks for the information cold war im only short in space about 1/2 inch for the exhaust manifold on the drivers side. I will try to shift the motor over . Butch eyota mn.
Old Nov 17, 2012 | 12:56 PM
64Rocket's Avatar
do a search for "Citcapp" '57 Olds. He did a 455 swap in his '57 which is almost the same frame.
Gene
Old Nov 17, 2012 | 02:16 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I'm not at all familiar with this swap, but was just wondering if using a '65-70 S manifold would help gain some clearance?
Old Nov 17, 2012 | 02:28 PM
dahl1car's Avatar
65 to 70 s exhaust manifold
Thanks ill look into it . Butch Eyota mn.
Old Nov 18, 2012 | 04:52 PM
2blu442's Avatar
How about the 1964-67 power steering pump? It mounts up high and will probably avoid the steering box. Here's some pictures, the top one is on a 1967 Toronado 425 and the bottom two are on a 1966 Cutlass 330. If you want to go this route I've got some extras of these, but to save on shipping you might create a parts wanted thread with your location. Then see if someone close by has what you need. John
I just read back through your post and found that the exhaust manifolds is hitting. I was thinking the power steering pump was the issue. Sorry.
Last edited by 2blu442; Nov 18, 2012 at 04:55 PM. Reason: Oops! I may have been on the wrong track
Old Nov 18, 2012 | 06:51 PM
citcapp's Avatar
You need to move the 455 off center to the passenger side of the car. The best fit for the cast iron header is the w/z cast iron header setup. You can get repo's from http://thorntonmusclecars.com/produc...aust-manifolds. I did the same conversion on a 57 Olds. Your power steering unit is a little larger. I had to move the engine as shown on the this diagram. you might have to move just a bit more. If you want more information send me a pm
File Type: pdf
bigjohn16678
Aug 7, 2014 10:57 AM
RandyS
Suspension & Handling
55
Apr 18, 2014 01:55 PM
Aron Nance
Sep 10, 2011 12:13 PM
Boldsmobile
Jan 17, 2011 06:40 AM
442oldslawyer
Jul 9, 2010 02:55 PM
