53 303 water pump pulley removal
Old Feb 22, 2017 | 02:43 PM
Tropicalbill's Avatar
Cool 53 303 water pump pulley removal
Need some advice on how to remove water pump pulley without damageing anything. Have radiator out and fan removed. Goal is to replace noicey water pump without removing front cover.
Old Feb 22, 2017 | 07:37 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Once you have all the bolts out and the fan off, the pulley should just slide off the water pump. If it does not then you have some rust between the pulley and the pump. You might want to pull the pump with the pulley on it and then work on separating them on while they are on the workbench. Good luck.
Old Feb 23, 2017 | 07:14 AM
Tedd Thompson's Avatar
X2 what Red said, you might soak the pulley and shaft for a day or two with your nut busting liquid of choice then tap it both ways with a hammer, it should come off pretty easly. Use a puller if it dosn't ... Tedd
at3reg98
Aug 13, 2013 10:16 PM
Johnny HR
Nov 3, 2012 12:22 PM
sshriber
Feb 25, 2012 07:36 PM
72Ctlss
Jun 23, 2009 03:12 PM
olds4life
Oct 10, 2008 07:28 PM
