442 questions
Old Mar 25, 2013 | 06:51 PM
Austin Trevor White's Avatar
442 questions
Hi, everyone. I just bought a 1972 442 auto with a 1974 455 in it. I've got a couple questions. First I've got 5 lines coming from the fuel tank. where do they all go carb and where else. The fuel pump has 3 lines ones suction and ones pressure. Do these have a return line?
Secondly all the vacuum lines have been removed, what are the basic ones needed to get it to run. I don't care about all that emission junk.
Thirdly my engine wiring is all screwed up. does anyone have an engine wiring diagram. Thanks
Old Mar 25, 2013 | 07:01 PM
Welcome.
Your questions, though not difficult, can all be answered much better by the Chassis Service Manual than by a few words from the members here.
I would recommend buying a copy (there are always a number on eBay) and, until then, downloading a copy for free from WildAboutCars.
That way you'll have your answers in minutes straight from the source, and you can begin to ask us the sorts of questions that the manual can't answer.
Old Mar 25, 2013 | 07:21 PM
Welcome, Eric is giving you some great advice. Oh and we love pictures, so post some when you get a chance.
Old Mar 25, 2013 | 08:11 PM
442 pics
Old Mar 25, 2013 | 08:21 PM
Looks like your well on your way.
Old Mar 26, 2013 | 02:59 AM
I agree, looks like a good start.
What makes you say it's a 442, though?
Old Mar 26, 2013 | 05:58 AM
Well it says 442 on the title, and it has the chrome 442 emblem on the trunk. So I'm just assuming that's correct. I haven't checked the vins or anything
Old Mar 26, 2013 | 06:50 AM
oldsmobiledave's Avatar
Fyi
SInce the W-29 442 options was merely an appearance package in 1972 the VIN will not discern a Cutlass that has the W-29 option from one that does not.
The car in the pictures has Cutlass grilles in it not 442 grilles. I do not see emblems on the fenders but that is likley due to the ongoing body work.
Good luck with your project regardless if it is a Cutlass or a 442.
Old Mar 26, 2013 | 07:03 AM
rocketraider's Avatar
Oldsdruid
72 is a weird year for 442. It went back to an appearance and handling option that year. On a 72 the VIN doesn't ID the car as a 442. You'll need to check other things.
A good clue to 442 is the rear suspension. It should have boxed control arms and a sway bar.
Right now your car has Cutlass grilles but any car could have had a nose job in 40 years due to accident damage.
1972 cars could also have come with either a 350 or a 455. An original 455 car will have U (automatic) or V (4-speed) engine code in the VIN. An original W30 car will have X.
H, J, K or M indicates it was originally a 350 car. Engine code is the 5th character of the VIN.
Don't get hung up on 442 or not. You have a 455 A-body that can be loads of fun.
On the fuel lines question- look in the front of the trunk up against the back seat and you'll see a tank looking thing which is fuel vapor recovery tank. The three vent lines you see coming from the corners and middle of the gas tank go to this thing, and the vapor line from the charcoal canister underhood also routes back to it. All it does is contain fuel vapors so they don't vent to atmosphere. When the fuel vapors condense back to liquid, the liquid fuel returns to the tank thru the line that comes off the middle vent line. Kind of a clumsy thing, but it doesn't take any horsepower to operate and it recovers your high-priced gasoline. Unless the underhood canister's filter plugs up, there is no way this thing can affect performance.
If you don't want to fool with it, simply blank off two of the tank vent lines and route one up above tank level so the tank will have a vent to atmosphere. That's all the factory did until emissions controls came along.
On wildaboutcars, find the 1972 Olds chassis manual and look in Section 8, Fuel & Exhaust. Look at Figure 8-5 for cutaway of the recovery tank and 8-17 for how the lines at the fuel tank are routed to it.
If your car came with a 455 it will have a 1/4" fuel return pipe on the frame near the 3/8" pump suction pipe. 350 cars didn't have them.
Far as vacuum lines required to run, if the emission stuff isn't a concern all you need are the transmission modulator and distributor vacuum advance. Trans is manifold vacuum, distributor is ported vacuum from the carb. You'll also need a manifold vacuum source to operate the a/c controls if it has a/c. Heater only cars used cables.
Old Mar 26, 2013 | 08:30 AM
You guys beat me to it, as far as the model designation goes, but I would add the clarification that because the 442 in 1972 was an appearance package option, and not a separate model, he may have an "Oldsmobile Cutlass 442" (subject to verification of what equipment the car has, and how original it appears), but he does not have an "Oldsmobile 442."
This would mean that the model designation on the title is incorrect (there was no Oldsmobile 442 in that year, and the "442" was not a model, but rather an option, like extra dashboard lights or power windows). This has no serious significance, and may actually add to its resale value, but it is good to be aware of.
Old Mar 26, 2013 | 02:22 PM
My vin is 3G87H2R132378. Since the 5th letter is an H i would assume that the original engine was a 350. I don't believe i have any 442 emblems that would go on the fender. The trunk says 442 but the glovebox door has cutlass written on it. I'm gonna have to confess ignorance on what boxed control arms are. I believe i've got a coil spring with adjustable air shocks. The car has factory air conditioning but manual windows. all help is appreciated. Thanks
Last edited by Austin Trevor White; Mar 26, 2013 at 02:27 PM. Reason: thought of something else
Old Mar 26, 2013 | 03:20 PM
Oldsdruid
3= Oldsmobile Division
G= Cutlass S 72 442 was available on Cutlass (F) and Cutlass S (G) coupes
87= 2-door hardtop coupe
H= 350, 2-barrel, single exhaust yes, there were 442 produced with this engine
2= 1972 model year
R= Arlington Texas assembly plant
132378= car's sequential VIN
Boxed control arms- regular lower control arms on the rear axle will be U-shaped. Boxed arms will have a metal plate welded on that effectively changes the U-shape to a "box" shape. The boxed arms are more resistant to flex than non-boxed.
72 442 could have had Cutlass glove box emblems. Like I said, 72 is a weird year for 442 and about the only solid proof is a build sheet or X engine code in the VIN, since only 442 could have the W30 option. Even if it's not a 442, enjoy the car with that 455. A 74 455 is smogged down a lot but the torque will still be loads of fun.
I'm guessing you're 18-25 years old with limited experience with older cars. We'll help ya.
RetroRanger's Avatar
72 Olds CS
the lower rear control arms are boxed meaning they have four sides for rigidity. The non boxed ones are a c channel (3 sides) with the open part at the bottom
Old Mar 26, 2013 | 05:26 PM
1970supremevert's Avatar
Welcome to the site, have fun with the car, just a fyi the right side headlight bezel is correct for 72 black background vs left side no black.
Old Mar 26, 2013 | 05:35 PM
starfire's Avatar
Bingo!
Old Mar 26, 2013 | 07:48 PM
since the later 455's were a little weak on power, what's it take to get them up to snuff?
Old Mar 26, 2013 | 08:56 PM
Oldsdruid
They're lower compression for one thing, and their J heads don't flow as well as other Olds heads. A set of big-valve C heads will be your biggest bang for the buck and they're common enough they shouldn't break the bank.
Olds changes compression ratio with the pistons and some 70s smog engine pistons could pass for soup bowls. For a nice streetable engine that can live on today's gasoline, about 9:1 CR will be great.
Decide what you want the engine to do and folks here can guide you thru it.
Old Mar 26, 2013 | 09:08 PM
sicky olds's Avatar
NôôB
On this note, the engine in my 69 has a bone stack short block from a 1976 Toronado. Just put my C heads on it and an Edelbrock intake manifold and it smokes the tires if i want. And the best part about that is it runs just fine off of low grade gas. Just a heads up .
Oh and it still does low 15's in the quarter mile with those soup bowls.
Old Mar 27, 2013 | 07:18 AM
72 w29 all green's Avatar
They're lower compression for one thing ...
ATWhite,
If you decide to go with new pistons, be certain to avoid these 40.3cc "soup bowls" (#L2390):
Old Mar 27, 2013 | 07:39 AM
droptopron's Avatar
delete
This is a good pic of boxed lower arms, if not a good price
http://www.opgi.com/p/suspension/11423/28/KR0445P.html
They have an insert welded in so it is four sided. They were required for a rear sway bar. Without it, the control arms would crush from the side to side pressure.
luckyman15
Jan 24, 2008 12:14 PM
viper771
Jan 10, 2008 07:06 PM
442fun
Mar 12, 2007 02:09 PM
Droptop
Jan 19, 2007 06:09 PM
hrazor35
Sep 17, 2006 06:45 AM
