425 Toronado engine rebuild advice
Old Feb 11, 2012 | 04:09 PM
toronado12's Avatar
Smile 425 Toronado engine rebuild advice
I need advice on 425 rebuild.
  1. Can I use any 4 bbl pistons OK. I know compression will slip from 10.5 to 10.25 to 1.
  2. Are all 425 timing sets compatible - excluding the cam which is Torondado unique.
  3. Does anyone have a economical source for pistons in .030 over?
  4. Any other advice would be appreciated.
  5. For those looking for a better deal on valve springs, 302 Ford makes a good interchange.
Old Feb 11, 2012 | 04:24 PM
Oldsmaniac's Avatar
You must use Olds 425 pistons and are available from EGGE. 2 or 4bbl makes no difference.
All modern Olds V8 time-ing sets should work regardless of cam.
The 425 Toro uses larger lifters also available from EGGE.
Jimmy Jo
Jul 7, 2014 01:01 PM
Nunyadam Biz
Dec 5, 2012 04:38 AM
sx455raidercelticfan
Nov 22, 2010 08:26 PM
Jonmueller1
Jul 16, 2010 07:18 PM
Threejdsolds
Apr 29, 2009 07:49 AM
