425 engine 1966 Toronado
Old Jul 14, 2010 | 09:13 PM
Jonmueller1's Avatar
I have set the timing at 7.5 degrees at 850 rpm; replaced the points and set dwell to 30 degrees, but am still getting backfiring through the carbeurater. Any suggestions of what to do next? THX JM
Old Jul 14, 2010 | 10:14 PM
Run to Rund's Avatar
Did you disconnect the vacuum advance at the pot on the distributor before setting timing?
Old Jul 15, 2010 | 04:57 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Old Jul 15, 2010 | 06:09 AM
Yes, I did and then i reconnected the vacumn advance afterwards. I am going to repeat the process. THX
Old Jul 15, 2010 | 07:35 AM
citcapp's Avatar
I assume it was backfiring before you did the tune up? Has the timing chain and gears ever been replaced? Might look there for your problem.
Old Jul 16, 2010 | 04:01 AM
Does that mean that the chain gets stretched and the valves open at the wrong time? I think this engine has a steel timing chain. Where would you even be able to get a new one?
Old Jul 16, 2010 | 11:45 AM
citcapp's Avatar
What is does is throw your timing off and you can't adjust it correctly because it keeps changing do to the slack in the chain. You can buy a timing chain and gear set at Rock Auto on the internet or at any quality auto parts store
Old Jul 16, 2010 | 12:59 PM
TripDeuces's Avatar
Is dwell 30 degrees or 20 on these, been awhile?
Old Jul 16, 2010 | 07:18 PM
svnt442's Avatar
30° +/- 2°.
rg1966cars
May 24, 2015 11:54 AM
patmills
Oct 20, 2014 04:08 PM
Jayycobb
May 31, 2012 05:50 AM
toronado12
Feb 11, 2012 04:24 PM
treasureroom
Aug 24, 2011 05:17 PM
