350 olds overheating
Old Mar 2, 2010 | 12:23 PM
84 supreme's Avatar
i have a 1977 350 olds motor that i had rebuilt and bored over .30, i put a elderbrock performer rpm package on it with the alum. heads,cam the usual stuff when u redo a motor. long story short i can cruise around town but when i decide to get on the highway it starts to overheat. got a 3 row radiator from autozone, flex fan didnt have a shroud, changed thermostats, carquest stock waterpump,even ran it without the stat, spring in bottom hose. still overheating any suggestions i would grately appreciate it. mike
Old Mar 2, 2010 | 12:32 PM
rock350it's Avatar
Had same issue with my 1969 350 and did the same stuff as you. I added a electric fan and problem was solved. now I run between 170-180 degrees.
Old Mar 2, 2010 | 02:09 PM
The fan has virtually no affect at highway speeds. That's why cars come with clutch fans. If the car is cool at idle but overheats at highway speeds, look at radiator size, internal blockage, collapsing hoses, sludge in the block, or something that's preventing coolant flow.
Old Mar 2, 2010 | 04:51 PM
Lady72nRob71's Avatar
Lean mixture or improper timing can cause overheating at speed, too.
Old Mar 2, 2010 | 08:09 PM
84 supreme's Avatar
installing a electric fan and new water pump this wkend. i thought about changing to an aluminum rad but i figure the 3row from autozone was sufficient enough. i guess i find out this wkend. thanks for the feed back mike
Old Mar 3, 2010 | 05:12 AM
Oldsguy's Avatar
Past Administrator
Glad to have you with us here and hope you can fix your overheating problem.
durbon885
Feb 24, 2023 07:06 PM
bigjohn16678
Sep 7, 2013 08:12 PM
Scottsauto
Jul 26, 2013 04:46 PM
danjothemonsta
Jun 5, 2013 09:30 AM
martine
Jan 3, 2004 11:29 AM
