1978 delta 88 heads and dual exhaust
I'm having trouble finding aluminum heads for my 78 delta 88, the descriptions only say 1976 and older. Will they work the same? And also I can't seem to find a dual exgaust setup for this car, will I have to piece one together? Thanks
Olds changed from 7/16" to 1/2" head bolts after the 1976 model year. You will need to open the bolt holes in any aftermarket aluminum heads to fit the 1/2" head bolts on your motor. I assume it's an Olds 350.
Olds never offered a dual exhaust system on the 1977-1990 B-body cars. The good news is that the chassis is the same as the one used on the 1991-96 Caprice/Impala. Walker Dynomax sells an aftermarket 2.5" cat-back stainless dual exhaust system for the Caprice that also fits the 1977-90 cars. RockAuto carries it. You will either need to modify your trans crossmember or find one for the 1994-96 Caprice that already has double humps for dual exhaust.
The Walker system is mandrel bent. Nearly every muffler shop will use a conventional bender that crimps the tubes at the bends.
I had to ask...
Harveydent13, I'm not making fun of you. Spending that much money on alum heads, carb, intake, and possibly a cam. Not doing anything to the lower end to boost compression is a fruitless exercise. Compounded by adding an extremely expensive exhaust, you accomplish nothing, in fact it may make it run worse.
You know what happens when you assume.
Half the story...
I had to ask...
Half the story...
I had to ask...
Its great getting more younger people into the hobby. Reading and asking questions is the logical way to research to make sure your money is well spent and your goals are achieved. This approach is applicable to any brand car.
I've been into Volkswagen and bmw, never really stuck and my step father bought me this car and I love it. I'm trying to research everything as much as possible before going forward with anything. I considered a mild 403 build on the side
Yes, I remember your first post, that your car only has 28k miles on it. There were quite a few valid suggestions made. Read the engines section for builds in your price range and since your contemplating a 403 you can also consider a 455 swap.
When the OP says that he's looking for aluminum heads, I'm not assuming.
The original 3A heads have 75-ish CC chambers. It doesn't take much milling on the aluminum heads to bump CR without changing the pistons. I personally wouldn't do it that way, but it doesn't suck.
Extremely expensive is a subjective term. The Dynomax kit I showed is $761 from Amazon. RockAuto currently shows it out of stock. I have no idea what a custom bent dual exhaust system with mufflers goes for from a muffler shop. Most shops here in Northern VA don't even do custom work like this any more.
84oldsDelta88
Dec 10, 2011 10:01 AM
