1970 Cutlass S
1970 Cutlass S
I purchased a 1970 Cutlass not too long ago. I actually came on here cause I am having issues with the low beams. Both are not working but all four are working on high beam. Checked the dimmer switch for continuity on both positions and it is good. Don't know where to go from here. Any help or direction to go on this site would be great. Thanks for all your help.
From the factory there were no headlight relays needed or used. If you have sealed beam headlights (even halogens) there is no need for the relays. As you have seen, they just add potential failure modes.
Ctls442
Mar 14, 2017 12:01 PM
jstrits
Aug 8, 2014 07:47 PM
halfmoontrail
Jan 20, 2013 05:46 PM
