1970 Cutlass S
Old Feb 24, 2018 | 05:49 PM
Roque Kerstin Gomez's Avatar
1970 Cutlass S
I purchased a 1970 Cutlass not too long ago. I actually came on here cause I am having issues with the low beams. Both are not working but all four are working on high beam. Checked the dimmer switch for continuity on both positions and it is good. Don't know where to go from here. Any help or direction to go on this site would be great. Thanks for all your help.
Old Feb 24, 2018 | 06:24 PM
lshlsh2's Avatar
71 cutlass convertible
Have you checked the low beam bulb. They have 2 filaments the low could be burned out on both. Welcome and show us some pics of your ride.
Old Feb 24, 2018 | 06:25 PM
Welcome to the site. Check for voltage at the low beam lamp connectors. If there is voltage there replace the lamps.
Old Feb 24, 2018 | 07:22 PM
I will take a look at those things. Thanks guys. Hope you like these pictures.
Old Feb 26, 2018 | 01:42 PM
So gents. Thanks for the help but found a wire disconnected on one of these bad boys.
The positive lead to pin 87 was just hanging there and not connected. DRRRR! Thanks for your help though.
Old Feb 26, 2018 | 01:51 PM
Someones aftermarket relay mod to fix dimming headlights.
Old Feb 26, 2018 | 02:19 PM
From the factory there were no headlight relays needed or used. If you have sealed beam headlights (even halogens) there is no need for the relays. As you have seen, they just add potential failure modes.
Old Feb 26, 2018 | 06:15 PM
Yellowstatue's Avatar
If they are using H4 & H1 halogen bulbs then a relay is needed because it will cause the headlight cct breaker to open on high beams without it.
Ctls442
Mar 14, 2017 12:01 PM
jstrits
Aug 8, 2014 07:47 PM
charlierogers
Oct 14, 2011 09:44 AM
